03-28-2007, 03:15 PM
#1
Installing a handrail
03-28-2007, 07:18 PM
#2
Handyguy
Should be between 30" and 34 " from top of tread (front of nosing) to top of rail. Where does that put it?
03-28-2007, 08:07 PM
#3
Lic. Builder/GC/Remodeler
Brik, no offense, but code should be 34" minimum and 42" maximum....from the nose of the tread....
Do you have different requirements in your neck of the woods?
Example:
http://nashua.qscend.com/filestorage/51/70/151/Deck.pdf
- Build Well -
03-28-2007, 08:10 PM
#4
Master Craftsman
I always install it at 36" to the top from the front of the step.
03-28-2007, 08:14 PM
#5
Same here, it keeps you safely in code without possible error...
(Hey Dave....we are agreeing again....  )
- Build Well -
03-28-2007, 08:15 PM
#6
HandB,
As mentioned, height code really is what will dictate the placement of the railing and it's hardware.
- Build Well -
#7
Master Craftsman
Go check the texture thread. If you would have said what you meant I would have agreed with you then.
03-28-2007, 08:17 PM
#8
 Sometimes, the brain refuses to work with the mouth...or in this case...the fingers...
- Build Well -
03-28-2007, 08:42 PM
#9
ok will do.
Where do you think I should buy the handrail? (the brackets and the handrail) ?
Does homedepot carry them?
03-28-2007, 08:46 PM
#10
Originally Posted by handbanana
ok will do.
Yes, they do.
However (sorry to throw this wrench into your plans)...
code requires returns on the ends of the handrail (if you intend to do it that way)
I wouldn't worry about it tho....that is up to you if you want to test some of your carpentry skills...
- Build Well -
03-28-2007, 08:49 PM
#11
Originally Posted by AtlanticWBConst.
Yes, they do.
Ok. Are handrails usually painted?
03-28-2007, 09:51 PM
#12
Generally...no.
If they are painted it is a very dark color.
They are usually stained and even protected with a non-gloss coating, since they will face finger prints galore....
- Build Well -
03-29-2007, 09:53 AM
#13
Handyguy
Originally Posted by [LEFT
No offense taken at all. I was unsure of the height and googled it. I still need to attach the handrail on my basement stairs (I left it off to make things easier for carpet guys). My local codes are not online and I have no future interactions with an inspector.
Anyway, first link I found in my google search was an OSHA link
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=22816
which says
§1910.23(e)(2) A stair railing shall be of construction similar to a standard railing but the vertical height shall be not more than 34 inches nor less than 30 inches from upper surface of top rail to surface of tread in line with face of riser at forward edge of tread.
Seems a second link, also from OSHA says
(6) The height of handrails shall be not more than 37 inches (94 cm) nor less than 30 inches (76 cm) from the upper surface of the handrail to the surface of the tread, in line with the face of the riser at the forward edge of the tread.
(7) When the top edge of a stair rail system also serves as a handrail, the height of the top edge shall be not more than 37 inches (94 cm) nor less than 36 inches (91.5 cm) from the upper surface of the stair rail system to the surface of the tread, in line with the face of the riser at the forward edge of the tread.
Another site that quotes the OSHA specs 30"-34" http://safetyis.us/stairs.htm
Regardless, I think 36" is a nice comfortable height. Not sure yet what I'll use.
Reason: fixed spelling
03-29-2007, 06:00 PM
#14
Home Improvement Guy
With you being 6'6" you'd probably want to go with the 42" maximum
03-29-2007, 06:14 PM
#15
Master Craftsman
Your absolutely right Ron. I've had to train myself to make sure and place things at normal people's height instread of my own. I would hold something up to be mounted and ask if that was ok and they would say, sure for you but you better move it down for me.
By the way, it's 6'9" not 6'6".
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
