-   -   Installing exterior door chain (http://www.diychatroom.com/f14/installing-exterior-door-chain-5470/)
joemz 12-18-2006 09:50 PM
I moved into a NYC apartment, and bought a chain to put on the metal apartment door.
But I can't find any screws that will hold in the metal. I put sheet metal screws in, but they have nothing to hold onto
I put plastic anchors in, but they pulled right out
The actual cavity that the screw goes into is pretty small, and the metal itself is obviously very thin, so a molly doesn't seem like it will work either
Any ideas?
Christopher 12-19-2006 08:16 AM
joemz,
One option is pop-rivets. Note: the hole size drilled in the door must be exactly the size specified on the rivet package.
...Christopher
majakdragon 12-19-2006 05:12 PM
I would think that the door has a framework around the edges. This would be where you should install the screws. Try drilling a small hole near the edge of the door and see if you get wood shavings coming out. (or thicker metal)
mcwilson 01-07-2007 10:07 AM
They actually make a bolt called a "sex bolt", (no kidding). It is a two-part bolt that bolts thru the entire door. The part that would be on the outside of the door is smooth so it can't be undone.
Hope this helps.
mcwilson
Tmb9862 01-08-2007 03:20 PM
Hope this helps.
mcwilson
Like a Carriage bolt? http://justinsomnia.org/images/carriage_bolt.jpg
A nut and bolt will do the job just the same, be sure to put the bolt head outside. They may be able to loosten it up a little but with a wrench but without acess to both sides they won't be able to completly unthread it.
I like the pop rivet idea personally though.
Another thing to take into consideration is ownership of the door. If you put bolts through my metal door, well you just lost your security deposit. Altough NYC landlords tend to be pretty lax on things like that.
