-   -   Installing curtain/drape rod in drywall/concrete block (http://www.diychatroom.com/f14/installing-curtain-drape-rod-drywall-concrete-block-54791/)
JRiegler 10-09-2009 07:57 PM
1 Attachment(s)
Just thought that I would post this in here. I didn't want to hijack someone elses thread.
A new house that I have purchased has three sliding glass doors. The walls are concrete block, with 3/4" furring strips and then 1/2" drywall.
I need to install curtain rods over all three, each with a length of 88". The center support should be fine, as there is a 4" piece of furring directly over the door (I went in and took pictures during framing). However, each end is going to be over the drywall. I can certainly try to hit the furring strip, drill through that into the concrete with a tapcon. However, I can't be certain that they are centered correctly on each side of the opening. If not, will the 3/4" gap between the drywall and the concrete be any cause for concern since there is no support? I dont want to crank down on the tapcon and cave in the drywall.
I hope that makes sense.
I feel a tapcon will offer the best strength (the only other option that I can think of is the e-z anchor), but I'm not sure how to move forward with no support behind the drywall.
If the top furring strips went all the way across, I would be a happy camper.
