Installing Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-31-2007, 12:36 PM   #1
New to the molding world so I have a couple of questions on the nailing of the molding.
When installing crown molding is it sufficient to just nail into the top plate or vertical joists? Do you need to nail the top and bottom of the molding? Do you use adhesive as well as nails?
fmolden is offline   Reply With Quote
Old 12-31-2007, 12:59 PM   #2
Home Improvement Guy
ron schenker's Avatar
If it's just a basic crown, that's what I do. Two inch brads top and bottom and also glued with "Liquid Nails" Many pros will recommend a wood backing for proper support, but I have done crown the way you are suggesting and never had a problem.
ron schenker is offline   Reply With Quote
Old 12-31-2007, 01:14 PM   #3
Thanks Ron
Old 01-02-2008, 04:55 PM   #4
Mod / ArchiBuilder
Cole's Avatar
What size crown?
Cole is offline   Reply With Quote
Old 01-02-2008, 06:48 PM   #5
4" and 6"
Old 01-02-2008, 07:06 PM   #6
Custom Cabinet Maker
Fmolden: First thing, I AM NOT BEING A SMART ASS. If you do not already know how to COPE then work on that First.
Second: DO NOT nail closer than 2 feet to the corners UNTIL you have the next pc installed and fitted. Reason is the crown will ROLL, this way you keep a block of wood in your apron and you can tap the crown and fit your corner until nice THEN nail it.
Also, take a short pc, maybe foot or foot and half, HOLD IT EXACTLY how it goes against the wall, slide it up till it just contacts the ceiling,pencil mark along bottom, do this in several place along every wall, expecially the corners, you want 2 lines into every corner, this is how you can keep it in proper position when you make the corners, tap bottom up or top down to meet this line.
good luck
skymaster is offline   Reply With Quote
Old 01-08-2008, 11:09 AM   #7
Master Procrastinator
I like to rip triangular strips of wood, thin enough to fit in the space behind the crown, then screw them to the wall securely. Then you can easily nail the crown to the wood strips. It holds the crown more securely, and keeps it from twisting. It also allows you to use smaller brad nails as they have far less distance to travel. Makes hanging crown much easier. And yes coping them is very worth it also.
mtaviator is offline   Reply With Quote
Crown molding termination at tile Stickboy Carpentry 4 12-26-2011 11:35 PM
Crown Molding: Lay flat or stand upside-down dtmbizzle Carpentry 15 09-27-2007 12:33 AM
Crown molding finish problem lewlewjones Carpentry 2 05-05-2007 08:13 PM
No experience, should I attempt crown molding? kristin Carpentry 7 02-03-2007 02:34 PM
Crown Molding Ramblnmn Remodeling 3 10-24-2006 10:08 PM
