Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-29-2009, 07:46 PM   #1
installing cabinets in washroom
I want to install cabinets in my washroom. the wall is concret and I want ot know the best way to attach them to the wall
dave56va is offline   Reply With Quote
Old 05-29-2009, 11:06 PM   #2
Lead anchors and screws will work.
Ron
Old 06-01-2009, 11:43 AM   #3
Tapcon concrete screws work really well. You must use the correct size drill and a hammer drill. Using a regular drill or a well worn bit will cause problems, the Tapcon will pull out or snap. It will also snap if the hole is not deep enough so be sure to get a long enough bit and drill at least 1/8” deeper than the Tapcon. If you buy cheap masonry bits figure two or three holes per bit. A good bit will last much longer and you will know it is shot out because the Tapcons will get harder to drive. You want about 1" of bite into the wall so be sure to consider the depth of the nailing strip on your cabinet and a washer if you use one. I prefer the Tapcons with a hex head and usually use a drill/driver or 3/8 ratchet. These are pretty expensive if you purchase a small quantity so look for the bulk boxes in your big box store. Usually you will find them half to a quarter the cost in bulk.
Rege
RegeSullivan is offline   Reply With Quote
Old 06-01-2009, 11:54 AM   #4
Old School
cabinetman's Avatar
WELCOME TO THE FORUM
If you use Tapcons, a 5/32" masonry bit works for 3/16" screws. A 3/16" bit works for 1/4" screws. You can use the same drill bit to drill right through your hang rail and the wall at the same time. Try not to wobble the drilling, as a nice straight hole works best.
cabinetman is offline   Reply With Quote
Old 06-03-2009, 10:01 AM   #5
The tapcon concrete screw is used by a lot of people in aplications like yours. The tapcon screw is easy to use and are not that expensive if bought on line. If you google tapcon you will find them alot cheaper than at any of your local big box stores. Be careful when installing the tapcon that you do not drive the screw into the concrete more than 1 3/4". If you do, the lead thread cutting the concrete will wear down and the screw may snap. The bit that you need will be in the box of screws when you make your purchase.
Bronx is offline   Reply With Quote
Installing Cabinets In Un-level Kitchen whiskeykid Carpentry 14 01-31-2009 08:43 AM
Installing Cabinets against/into door moulding/casing DanBress Interior Decorating 6 08-19-2008 11:36 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
Installing wall cabinets GearHd6 Remodeling 26 11-12-2007 08:06 PM
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 07:12 AM
