Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-26-2008, 04:16 PM   #1
Installing cabinets on exterior concrete wall
I want to install cabinets in my laundry room on the exterior wall.
The wall is cinder block (in the basement) and is covered with drywall.
It also has an electrical box and a few pipes - that I could possibly cut into the cabinet...
I know i will need to anchor it - and I was going to use 1/2 sleeve anchors to attach 2x6 strips (that I can later attach the cabinets to).
Am I going to have a problem with the drywall and foam insulation? or do I need to cut it away so the 2x6 is up against the concrete block?
I was hoping the 2x6 would give me enough distance from the wall -- that the pipes and electrical tubing won't be an issue.
Thanks!
~Jenni says ~ is offline   Reply With Quote
Old 01-26-2008, 07:38 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Why not install a section of plywood instead of the 2x6 strips. You can use adhesive to install the plywood onto the drywall. Cut the plywood smaller than the cabinet, so it is not visible. Install it using washers with your anchors. If the anchor heads do not site flush and interfere with the cabinet mounting, you could install some furring strips.
If there is a visibly large gap at that point around the cabinets, then you could install filler strips or some narrow molding, to hide the gap.
?? just my 2 cents ??
- Build Well -
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 08:48 PM
Installing wall cabinets GearHd6 Remodeling 26 11-12-2007 08:06 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 07:12 AM
