Installing A Cabinet In Toilet Room - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-15-2010, 07:24 PM   #1
Installing a Cabinet in Toilet Room
I want to install a cabinet in my toilet room above my toilet.
It looks as though the wall is 33 3/4" wide.
If I install a cabinet that is 33 1/2" in there, is that ok?
Can I just fill up the remaining small space on both sides with caulk or something?
thank you
limitdiy is offline   Reply With Quote
Old 07-15-2010, 08:04 PM   #2
Rewards Points: 262
Are you talking about something that recesses into the wall cavity between the studs? Wall studs are typically spaced 16 and 24 inch on center.
Jim F is online now   Reply With Quote
Old 07-16-2010, 12:09 PM   #3
gmhammes's Avatar
If it is not recessed you shouldn't need to caulk it. If you want it to look finished though you could use quarter round.
gmhammes is offline   Reply With Quote
Old 07-16-2010, 12:24 PM   #4
47_47's Avatar
Rewards Points: 44
As long as the cabinet doesn't have hinged doors, you are ok. Use a molding to cover the gaps as suggested.
47_47 is offline   Reply With Quote
Old 07-16-2010, 12:37 PM   #5
there's no recess....its just a little water closet/toilet room....
its about 33 and 3/4 inches wide....
yeah, I'm talking about filling in the gaps....
is it called molding or quarter round?
Old 07-16-2010, 01:11 PM   #6
gmhammes's Avatar
Usually it's referred to as quarter round. it you want something larger then it would be molding.
Old 07-16-2010, 02:21 PM   #7
Rewards Points: 262
Oh, that's the width of the room.
Old 07-17-2010, 12:19 AM   #8
Registered User
Rewards Points: 4,902
Must be a local thing: http://awi-wa.com/Mould_Prod6.htm
Be safe, Gary
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Installing a toilet over harwood floor caglezs Plumbing 5 02-08-2008 12:23 AM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 11:59 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
Installing new toilet flange. helpless handyman Plumbing 7 11-16-2007 07:47 PM
