Hello,
I am renovating my bathroom in an old century home and am using 4' x 8' sheets of beadboard panelling for the wainscotting. The walls of the bathroom have been gyprocked and primed. I am ready to install the beadboard. It is my intention to cut the panelling into 4' x 4' sheets ~ as the wainscotting will run 48 inches up from the floor (give or take for levelling). It is my intention to install the panelling with the factory edge at the top; the top will be covered with chair rail, the bottom will be covered with baseboard. It is my thought that the best way to install the panelling is to apply PLP Premium adhesive to the back of the beadboard and then afix with a nail gun or finish nails.
The design of the panelling is a series of vertical strips ~ 2" wide followed by 3/8 wide, 2", 3/8", 2", 3/8", etc, etc, etc. You get the idea......
My question is two-fold: a) Where do I put the first sheet of beadboard and b) what do I do at the seams and corners? The walls of my bathroom are approximately 6 feet long (not exact). I want the width of the corner "strip" to be exactly 2". That is, if one board ends, say, 1.5" into a 2" strip, I want to cut the adjacent board so there is 0.5" of a strip butting up against it so that, to the eye, the pattern of 2, 3/8, 2, 3/8, 2, 3/8, etc, etc. is not interrupted. [Of course, if you see 1.5" of a strip at the end of one wall, that strip of beadboard is ACTUALLY wider than that (for example, it would be 1.75" if the beadboard butting up against it is 1/4" thick).
So..... to make the cleanest cuts (I'm really, really novice at renovating), should I use a table saw or a skil saw with a guide? Should I pick one corner to start at a factory edge ~ thereby making all other corners at variable positions of the vertical strips OR should I find the middle of each wall and centre a full sheet on each, thereby making all corner the same appearance? (The second choice would seem like a far more professional, consistent approach ~ just more work, more seams, more waste.) Maybe there is another way I haven't thought of?
I hope I have asked my question well; I think it seems kind of confusing but I'm thinking if anyone out there actually knows what I'm talking about then you know what you are doing (if you know what I mean).
Thank you very kindly for any input you have to offer!
Karen
Karen
