Installing Baseboards - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-21-2014, 09:12 AM   #1
Installing baseboards
I'm installing .688 X 5.5 inch MDF base moulding into drywall above wood floors. I've already made the cuts and I'm ready to nail them into the wall. I have have three questions:
1. I have a cordless nail gun that can handle 2-inch finish nails. Will these be long enough?
2. Should I put the nails in perpendicular to the baseboards and into the studs? (I saw somewhere that you can angle one of the nails into the floor).
3. Should I use nails at each stud? And how many per stud - two?
mdrisk is offline   Reply With Quote
Old 04-21-2014, 10:29 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
2" is a little short. You might be able to use them if you put 1 in straight in each stud and want straight into bottom plate below it. I would use a 2 1/2" or better 3". If you use 3" you could angle your nails a little.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
mdrisk (04-21-2014)
Old 04-21-2014, 03:29 PM   #3
Rewards Points: 13,468
Base is not nailed to the floor, to the bottom plate and the studs only.
Old 04-21-2014, 08:17 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
and DO NOT USE 3" nails !!!!!!! theres too much chance of hitting a pipe or wire.
when im installing baseboard i use 1 1/2" 18 gauge nails for cheap 3/8" thick mdf and pine baseboard, for 3/4 baseboard be it mdf, pine or hardwood i use 2" 16 gauge
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
DIYRemodeler (04-22-2014), jaydevries (05-10-2014)
Old 04-29-2014, 08:41 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
On the 5-1/4 sped base i always put 2 nails per stud. I find that 2-1/2" nails work much better especially when y have a stubborn bow in the wall and you need to pull the base in tight. I also like 2-1/2 because you can angle them slightly into the stud and still catch them. 2" will work fine though
Millertyme is offline   Reply With Quote
The Following 2 Users Say Thank You to Millertyme For This Useful Post:
joecaption (04-30-2014), spower (04-30-2014)
Old 04-30-2014, 07:03 PM   #6
miller is right but with 2 1/2" nails you run the risk of hitting a pipe or wire inside the wall cavity which can cause a leak which wont be noticed right away or if its a wire can start a fire.. hence using 2" nails
Old 05-01-2014, 11:06 PM   #7
I always use 1 3/4 to 2" nails for base. 9/16 thick base and 1/2 inch drywall gives you roughly 3/4" penetration into the studs, which is usually fine. I would not recommend nailing into the bottom plate willy nilly as pipes are usually run through that inbetween stud bays.
I have seen nails go into pipes and seal themselves up for sometime before finally letting loose when you least expect it.
uncommon doors is offline   Reply With Quote
Old 05-02-2014, 06:20 PM   #8
uncommon you pretty much hit the nail dead on with that, what happens is that the nail will rust away slowly then the water can finally come out of the hole int he pipe.
i have a a couple friends that are site superintendants with fire and water damage restoration companies and they see it all the time.. typically it isnt until 2 years later that its discovered
The Following User Says Thank You to woodworkbykirk For This Useful Post:
uncommon doors (05-05-2014)
Old 05-07-2014, 11:27 PM   #9
Don't assume studs are where you think they are and justs start shooting everything. Gently cut out holes in the drywall that will be covered with the moulding anyway or patch them after to make sure you're actually shooting into wood without hitting wires etc. You might even want to just glue it and hold the moulding tight while the glue dries with like 4x4 lumber and return the 4x4s after or something like spring loaded shower rods and have them spring out from a heavy couch or something.
calypso121 is offline   Reply With Quote
Old 05-08-2014, 07:07 PM   #10
or use the proper size nail so your not spending a full day extra cutting holes in drywall then patching it
Old 05-08-2014, 07:18 PM   #11
4 X 4's, punching holes in the sheetrock, gluing it, and propping it in place.
Please do not do any of that!
It's just going to slow you down and waste time.
Old 05-08-2014, 09:08 PM   #12
Rewards Points: 388
Very bad advice. If the op needs o find studs, use a 16 p finish nail and poke through where you SUSPECT that there might be a stud (assuming that you did not do the correct thing and MARK all of the studs on the floor/wall!) like either side of an outlet, etc. then measure 16" from that and test again.q. Have NO idea why someone would want to take what are essentially deck posts and use them to hold baseboard in place. Ron
ront02769 is offline   Reply With Quote
Old 05-09-2014, 02:36 AM   #13
lol
If someone ran a wire/pipe through the stud/wall footer without a metal shield to at least hopefully stop the nail gun, he could potentially hit it. Takes what, 30 seconds to confirm there's a good stud there, and then 8 seconds to hit it with spackle since the hole's hidden behind the moulding anyway?
Originally Posted by ront02769 View Post
Very bad advice. If the op needs o find studs, use a 16 p finish nail and poke through where you SUSPECT that there might be a stud (assuming that you did not do the correct thing and MARK all of the studs on the floor/wall!) How would he know exactly where the studs are unless he just built the wall and marked them? Gently gouge out a little bit at a time with something like a flat screwdriver, tapping in nails could be as bad as shooting them. like either side of an outlet, etc. then measure 16" from that and test again.q. Yes, check 16 OC and hope they built it right. Just don't go shooting everything assuming it's 16Oc and the footer has no wires/pipes/etc in it. Have NO idea why someone would want to take what are essentially deck posts and use them to hold baseboard in place. Ron In case they just want to glue it.
Old 05-09-2014, 06:03 PM   #14
well for one thing no plumber or electrician with any sense will run pipes or wires through studs less than 16" off a floor.. the chances they would do so between 4-6" off a floor are even less. it increases the chance of getting hit by a nail and also by drilling that close to the end of a stud it weakens the wall assembly. if they were to do so it wouldnt pass an inspection
Old 05-09-2014, 06:37 PM   #15
they might have gone vertically through the footer with pipe/wire, and they might staple the wires to the sides of the stud/footer too close to the sheetrock.
install tile flooring and new baseboards Margaret1450 Flooring 1 04-17-2012 05:52 PM
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 02:21 PM
New carpet or baseboards..which is first? Doubleg71 Flooring 7 03-08-2012 05:49 AM
contractor installing vinyle with baseboards on still djsmith1969 Flooring 3 08-30-2011 09:14 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
