Installing Baseboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 07:13 PM   #1
Im installing baseboard trim over wood flooring, Im not sure how much of a gap I need to leave inbetween baseboard and hard wood floor. Im doing it this way because I'm planning on having carpet installed later. Any suggestions?
LOUSY CARPENTER is offline   Reply With Quote
Old 10-28-2010, 07:27 PM   #2
jlhaslip's Avatar
Rewards Points: 1,502
Ask the carpet supplier/installer.
I have used everything from 3/8" to 3/4" depending on the thickness of the carpet.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
LOUSY CARPENTER (11-03-2010)
Old 10-28-2010, 07:29 PM   #3
remodeling pro
That depends on the type of carpet you plan on. 1/2" to 9/16" (the thickness of the average production base trim used as a spacer) works ok if you have a typical 1/2" pad and 1/2" or more pile carpet. You will need less for a Berber type rug w/ pad, and still less for a Berber or very short pile commercial type of rug without a pad.
troubleseeker is offline   Reply With Quote
The Following User Says Thank You to troubleseeker For This Useful Post:
Old 11-03-2010, 11:07 PM   #4
Thank you for your reply Ive heard anything from a 1/4" to 3/4" and I went for the inbetween 1/2" , and it worked great. Thats what I like about this site, you can always get a second or more opinion about what your doing if your not sure or second guessing yourself. Thanks for the help.
Old 11-03-2010, 11:29 PM   #5
Wood Flooring & Carpentry
lawndart's Avatar
You could've taken the guess work out of the equation if you installed the base moldings after the carpet installation. Glad it all worked out for you
lawndart is offline   Reply With Quote
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 11:41 AM
installing baseboard on CI steam system? wombosi Plumbing 17 06-07-2010 07:04 PM
Installing a cast iron baseboard secutanudu HVAC 1 03-21-2010 08:12 PM
Installing baseboard trim on curved wall billyg Carpentry 8 02-06-2009 08:25 AM
Installing baseboard trim helpless handyman Carpentry 4 10-05-2007 09:16 AM
