Installing An Attic Above My 2 Car Garage - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-17-2008, 12:33 PM   #1
John
Question
Installing an attic above my 2 car garage
I have a two car garage with gable roof which has not had a ceiling attached, and so is open up to the rafters. I want to install an attic above with pull down stairs for access.
Questions:
1.) Should I sister the bottom chords with beams larger that what the bottom chords are built with?
2.) Should I install verticle braces between the top and bottom chords around the drop-down stairs frame?
3.) Can the webs be replaced with verticle supports?
jdavid is offline   Reply With Quote
Old 07-17-2008, 12:40 PM   #2
Licensed Contractor
If you have trusses, which it sounds as though you do, you cannot modify them without either the original mfgr approval (good luck finding out who they are) or an engineers stamped plans.
Although people use the attics formed by trusses for storage, they are limited to light duty storage, such as Christmas decorations, luggage, etc.
Modification of trusses, such as cutting chords, removing webs. etc., will cause your next house insection to fail, about the time you were hoping to sell. Don't do it without proper review and approval.
Renovator,LLC is offline   Reply With Quote
Old 07-17-2008, 12:50 PM   #3
Rewards Points: 1,910
It totally depends upon what you want to use it for and what it was currently designed for.
What do you want to use the attic space for?
Are there any markings on the trusses to indicate who manufactured them? Can you get info from the builder on the trusses? Is there anything filed with your local building dept on the trusses?
Tags
attic , garage , truss
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Cost of installing Attic Furnace in new construction marejw HVAC 3 01-11-2008 05:00 PM
Installing garage door ??? coltsfan Remodeling 5 08-11-2006 02:59 AM
