Installing 24" Granite Tiles Over Existing Kitchen Countertop? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-24-2008, 09:41 PM   #1
DIYer
Question
Installing 24" granite tiles over existing kitchen countertop?
I am going to install 24" granite tiles on my kitchen countertop. From what I have read it is important to make sure the cabinets are screwed to the walls and to add corner braces for extra support. My existing countertops are particle board with laminate. They are in good shape. Will they support the weight of the tile? I plan on roughing up the laminate with sandpaper and then unsing prolastic to set the tiles in.
pford is offline   Reply With Quote
Old 01-24-2008, 10:06 PM   #2
so-elitecrete
Rewards Points: 150
granite weighs 180#,,,
per cf as i recall,,, some slightly more, some less,,, you can do the math,,, if it were mine, i wouldn't trust particle board in my home.
so-elitecrete is offline   Reply With Quote
Old 01-25-2008, 11:00 AM   #3
I agree with so-elitecrete as far as particle board(bad,bad,bad).
If I were to spend the money the granite tiles cost, I would remove the old counter tops and install 3/4 inch plywood as a base and then cover with backer board to be safe. I sometimes over do it, but want to only do the work once not to mention having to spend twice money because I cut corners first time.
Just my oppinion!
kjwoodworking is offline   Reply With Quote
Old 01-25-2008, 11:16 PM   #4
Rewards Points: 5,336
Particle board is a no,no. If it's been up for a while it's already coming apart under the front lip in front of the sink and dishwasher. You'll see problems around the sink and faucets also. Build it right and built it once.
Ron
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
I need advice on installing self-adhesive floor tiles SavReb Flooring 2 11-20-2007 10:09 PM
Tiles over existing vinyl Work is good Flooring 3 07-11-2007 11:10 PM
Installing 'peal and stick' vinyl squares on top of existing .... alexz Flooring 8 02-17-2007 05:20 PM
Bathroom Tiling - On top of existing tiles??? moggiex Painting 8 12-13-2006 06:17 AM
