Installed Pocket Doors, Now How Do I Remove The Wood To Install The Hardware - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 05:48 PM   #1
Installed pocket doors, now how do I remove the wood to install the hardware
I just installed a couple pocket doors and am stumped how do I remove the wood to install the hardware. Do I use a router? Do I go free hand?
This is the type of hardware I'm trying to install.
amdspitfire is offline   Reply With Quote
Old 11-20-2008, 06:02 PM   #2
the Musigician
DangerMouse's Avatar
http://www.johnsonhardware.com/install.htm scroll down to pocket door locks. this may help.
love my pocket doors.... =o)
DM
Old 11-20-2008, 06:24 PM   #3
All trades carpenter
Pencil some cut lines on the door that represent the area needed to be cut out. Then drill some 1/2" holes at each corner. Use a jig saw to cut the rest of the square out. Don't forget to put some tape down so the jig saw does not scratch the door or the cut does not splinter!
CrpntrFrk is offline   Reply With Quote
Old 11-20-2008, 09:20 PM   #4
DM
Good link, thanks.
Now I need a jigsaw
Old 11-21-2008, 06:07 AM   #5
Rewards Points: 5,336
If this is a hollow core door, you can use a hand saw and a utility knife if there are no lock blocks.
Ron
Old 11-21-2008, 10:51 AM   #6
Ron
Not hollow core.
Old 11-21-2008, 10:57 AM   #7
the Musigician
personally, i always use a chisel, razor sharp, to install hinges, pocket door locks, etc. more control that way for me.
DM
Old 11-21-2008, 10:58 AM   #8
the Musigician
oops, was gonna ask, did the lock come with a mounting template? possibly 'built in' to the instructions?
DM
Old 11-21-2008, 02:43 PM   #9
hello,
I found this great video for you on the topic of pocket doors and hardware.
Check this out-----Installing a Pocket Door
And if that does not solve it for you, it may help someone else here.
sam999 is offline   Reply With Quote
How to remove mildew from wet wood bofusmosby Carpentry 11 07-16-2008 02:16 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
Pocket Doors Question flyultralite Building & Construction 2 02-27-2008 11:35 AM
How to remove faux wood ceiling beams? hfoster Remodeling 2 02-11-2008 10:11 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 08:21 AM
