Install Hooks In A Concrete Ceiling? - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 04:01 PM   #1
Install hooks in a concrete ceiling?
Hi,
I live in an apartment in NYC and the ceiling is solid concrete. I what to hang a rack from the ceiling in the kitchen to hold pots. The kit I bought attaches to the ceiling by a hook but is only designed for wood or drywall. Is there some type of concrete anchor that give your a hook on the end of it? I have mounted other things to my ceiling using the regular concrete anchors but for this I need it to have a hook to attach to.
Thanks for the help!.
adamsanderson is offline   Reply With Quote
Old 07-26-2011, 05:09 PM   #2
Rewards Points: 5,336
Screw in "eye" hooks into the ceiling.
Ron
B. Franklin 1759
Old 07-26-2011, 05:37 PM   #3
Rewards Points: 37
Check Mcmaster Carr, bet they have something.
RodBarney is offline   Reply With Quote
Old 07-26-2011, 06:02 PM   #4
AGWhitehouse's Avatar
Are there structural beams visible? If not, better check with someone who know's the building. Some concrete floors are tensioned with steel rods. Drilling holes in the wrong spot could cut the wire and create a structural hazard.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following User Says Thank You to AGWhitehouse For This Useful Post:
tpolk (07-27-2011)
Old 07-26-2011, 06:21 PM   #5
Rewards Points: 558
you need the second one:
epson is offline   Reply With Quote
Old 07-27-2011, 08:58 AM   #6
Thanks for all the quick replies.
@Ron6519 - With an eye hook is the procedure to drill into the ceiling with a masonry bit and then simply screw the eye hook into the hole? I just remember when I used concrete screws in the past it was pretty hard to get the screws in even using a power screw driver. With the eye hook I guess I'd have to do it by hand or stick a screw driver through the eye and twist it from there?
@epson - What is the second one in the photo actually called?
@AGWhitehouse - I can't see any beams - its a is a new apartment building about 12 months old - 40 stories.
Old 07-27-2011, 11:25 AM   #7
Might be worth it to ask...They might have used pre-stressed planks or a tensioned slab system, both of which have steel tensil rods that essentially hold the concrete up. While cutting one likely won't bring the building down, you'll have a really mad landlord on your hands.
Old 07-27-2011, 11:40 AM   #8
You would use an anchor to screw the eyehook into just like the screw.
You can use an open hook or a closed loop in the ceiling. You will hang the unit on "S" hooks.
Ron
B. Franklin 1759
Old 07-27-2011, 11:47 AM   #9
if there are drop ceilings lift a panel and have a look how they are hung
The older I get the better I was
Old 07-27-2011, 12:01 PM   #10
fabrk8r
fabrk8r's Avatar
Wej-it concrete fastening systems
http://www.toggler.com/wejit/
All you'll need besides the fasteners is a hammer drill and the correct size masonry bit.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 07-27-2011, 09:19 PM   #11
Rewards Points: 558
Itís called a sleeve anchor here is another link: http://ca.images.search.yahoo.com/im...mb=sLdR712xJ51
Old 07-29-2011, 10:19 AM   #12
Too Old
I really doubt you can drill through a post tension cable using a small masonry bit. I have seen guys hit the cable trying to drill with a 3/4 bit using a Hilti and had no damage to the cable.
havalife is offline   Reply With Quote
Old 07-29-2011, 10:53 AM   #13
Rewards Points: 150
Coulld you glue decorative wood blocks to the ceiling and screw into them,, you're not talking about that much weight..
josall is offline   Reply With Quote
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Vapor barrier in tub/shower stall with exterior wall... OK to install Schluter-KERDI over concrete board? tzinho Tiling, ceramics, marble 1 01-24-2011 09:58 PM
concrete ceiling joist(beams) stacey2345 Building & Construction 12 01-24-2011 05:07 PM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
