#1 |
instaleing a new cieling
we have 10ft ceiling in the kitchen and living room and we are lowering them too 8ft and we are just woundering if we have too in insulat the lowed ceiling when the excieing ceiling is fully insulaed already
#2 |
Whatamess
With todays heating prices I would insulate all I can.
I may go home hungry, but not tired and hungry. |
#3 |
The rule of thumb is if you want heat or cold to stay where it is then insulate.
My idea of a perfect day: No where to go and all day to get there. |
#4 |
Lic. Builder/GC/Remodeler
The key is going to be what your interpretation of "fully insulate" means.
Check to see what the requirements are for your region, then check what is in place. If the ceiling areas are insulated to the requirements for your region, then adding additional insulation, is just going to be overkill, and a waste of time and money.
- Build Well - |
#5 |
gravity always wins
Having two insulation systems interrupted by a large air void could be setting yourself up for moisture condensation issues. You would be creating an unvented plenum. If the air temperature in that space ever drops below dew point, get ready for a host of problems. You'd be better to lower the insulation system down to ceiling level and vent above it.
| Display Modes | |
| Metal framing for basement Drop Cieling? | joliet_man@yahoo.com | Carpentry | 3 | 10-22-2008 02:16 PM |
| Non-IC rated lighting in Insulated cieling. OOPS! | MyMonkey | Electrical | 7 | 02-22-2008 10:46 PM |
| Cieling Beam Help Asap!!! | RSOPNCO1 | Building & Construction | 8 | 01-07-2008 02:11 PM |
| sheetrock cieling? old house | jamesdart | General Discussion | 4 | 10-09-2006 04:36 PM |
| AFRAME false cieling | paul kern | Building & Construction | 1 | 09-28-2005 09:37 AM |
