-   -   instaleing a new cieling (http://www.diychatroom.com/f14/instaleing-new-cieling-32245/)
onepercangel 11-20-2008 12:51 AM
we have 10ft ceiling in the kitchen and living room and we are lowering them too 8ft and we are just woundering if we have too in insulat the lowed ceiling when the excieing ceiling is fully insulaed already
TazinCR 11-20-2008 03:00 AM
With todays heating prices I would insulate all I can.
Marvin Gardens 11-20-2008 09:43 AM
The rule of thumb is if you want heat or cold to stay where it is then insulate.
AtlanticWBConst. 11-20-2008 11:09 AM
The key is going to be what your interpretation of "fully insulate" means.
Check to see what the requirements are for your region, then check what is in place.
If the ceiling areas are insulated to the requirements for your region, then adding additional insulation, is just going to be overkill, and a waste of time and money.
Maintenance 6 11-20-2008 12:41 PM
Having two insulation systems interrupted by a large air void could be setting yourself up for moisture condensation issues. You would be creating an unvented plenum. If the air temperature in that space ever drops below dew point, get ready for a host of problems. You'd be better to lower the insulation system down to ceiling level and vent above it.
