Inside Corner Cuts For Crown Molding - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 07:25 PM   #1
inside corner cuts for crown molding
what degree cut for inside cornerjoints for crown molding
livy is offline   Reply With Quote
Old 03-26-2012, 09:36 PM   #2
Haverhill Trade 1965
Inside corners should almost always be coped not mitered. Any loose fit will be pushed away by the nails opening the joint. If you must miter it the angle is one half the angle of the corner. 90 / 2 = 45. to cut molding put it in the saw upside down and backward. (right end joint cut left end with molding top down).
Duckweather is offline   Reply With Quote
Old 03-27-2012, 11:38 AM   #3
Rewards Points: 77
Just below your sign in block in the upper right corner you will see "search". Click it and type in coping crown molding. There has been endless discussion about this topic here. Just read the replies.
MNsawyergp is offline   Reply With Quote
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
First coat on inside corner, need advise.. helpless handyman Building & Construction 6 09-24-2008 12:22 PM
measuring inside corners for crown molding peciousroy Carpentry 13 08-04-2008 05:39 AM
Building a deck on an inside corner ternstes Carpentry 3 06-16-2008 08:45 PM
Baseboard - inside corner Potomac101 Flooring 11 02-16-2008 10:44 AM
