Impossible To Nail! - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-06-2009, 11:05 PM   #1
Impossible to Nail!
Hi I'm trying to hang some shelves against a wall in my house, this is a very dense plywood and it's taking me about 30-40 very hard hits to put one nail through 5/8".
Do you have any suggestions how I can make this easier? I'm using a spiral standard 1 1/2" nail. Should I just drill a hole and use screws?
Thanks!
Ashika is offline   Reply With Quote
Old 09-06-2009, 11:50 PM   #2
Rewards Points: 336
Is it possible there's a metal plate covering the part of the stud you're nailing into? A plate that's protecting electrical wires or plumbing that's running through the stud?
Just a guess.
gma2rjc is online now   Reply With Quote
Old 09-06-2009, 11:51 PM   #3
Its not the stud that's hard to nail into but the wood itself! The stud is very easy and I've nailed countless types of woods without any problem, this wood that I just bought is however extremely difficult.
Old 09-07-2009, 12:31 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you want to use nails, drill a small pilot hole in the plywood. You want it small enough so the nail will still have tension in that piece of wood but it will not have to do the actual piercing of the wood. Do not pre-drill the stud in the wall.
Old 09-07-2009, 01:29 AM   #5
Wouldn't it be easier or more advantageous to use screws instead?
Old 09-07-2009, 02:20 AM   #6
general contractor
A.W.Davis's Avatar
Agreed with Ashika. If your going as far as pre-drilling the wood to make it easier to nail, you might as well just use screws. I would recommend using 2" screws.
A.W.Davis is offline   Reply With Quote
Old 09-07-2009, 02:34 AM   #7
nap
You talking to me?
nap's Avatar
that's what I would have used from the beginning but you seemed to want to use nails. I simply told you how to use nails.
A.W.Davis Agreed with Ashika. If your going as far as pre-drilling the wood to make it easier to nail, you might as well just use screws. I would recommend using 2" screws.
there are a lot of times that wood must be pre-drilled and nails are still the preferred attachment. You use what is the best for what you are doing whether it is nails or screws.
Nail gun shock injuries dswan388 Safety 5 06-17-2009 01:21 PM
Nail gun shock injuries dswan388 Roofing/Siding 11 11-24-2008 07:34 PM
Nail gun shock injuries dswan388 Tools 5 11-02-2008 09:46 PM
framing nail went throug PVC pipe amakarevic Plumbing 8 10-06-2008 05:43 PM
Nail Gun Plastic Nail Casing frustrations smark General DIY Discussions 6 07-07-2008 09:10 PM
