IKEA Butcher Block - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2012, 10:17 AM   #1
Rewards Points: 27
IKEA Butcher Block
We are installing an IKEA butcher block and we started sanding the top coat off so we could put our own sealer on - we noticed one spot that actually looks like a veneer is coming up. Any solutions to glue this down/fill w wood filler/solidify before sealer goes on??
You can feel this 3/4"square spot lifting when you press on it and we don't want it to wear over time after we seal it
IKEA Butcher Block-image-76632158.jpg   IKEA Butcher Block-image-2106741088.jpg   IKEA Butcher Block-image-1176681056.jpg
RomanDesign is offline   Reply With Quote
Old 12-28-2012, 11:56 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Its does not appear to be a veneer. It looks more like they cut that section incorrectly when it was being milled or there was a defect in the wood already.
Easiest thing to do would be to fill that area with a good epoxy wood filler and then sand it down. That will bond that area and deter further lift and the stain/sealer will take to it like wood.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (12-28-2012)
Old 12-28-2012, 03:25 PM   #3
That's not veneer, the guy above gives good advice
Develin is offline   Reply With Quote
Old 12-28-2012, 03:35 PM   #4
Rewards Points: 27
Thanks so much for the reply. We looked for "epoxy" wood filler and could only find regular wood filler. Called Lee Valley and they said they have a 2-part substance that might work -- mix the two parts together and make a putty.
I'm hesitant just because I want it to match the Colour of the existing wood and absorb the sealer in the same fashion.
Any brand names you could recommend? And/or stores I can check out?
Old 12-28-2012, 05:49 PM   #5
kwikfishron's Avatar
Rewards Points: 176
Why can't you just return it and get another one?
That's called "checking" btw and occurs naturally in wood sometimes. It's nobody's fault but it has no place in the butcher block they sold you.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
oh'mike (12-28-2012), Windows on Wash (12-28-2012)
Old 12-28-2012, 09:43 PM   #6
Ron,
Didn't know the formal term. Just Googled some pictures and never knew that is what it was called.
Learn something new everyday.
Old 12-28-2012, 10:16 PM   #7
Rewards Points: 176
You can sand checks until the end of time and get nowhere. It's (I think) a failure of the natural bond of growth rings.
Would you butt or miter a butcher block counter top if... Big-Foot Kitchen & Bath Remodeling 15 12-13-2012 03:38 PM
Cutting maple butcher block with skill saw jep Carpentry 5 09-16-2012 08:40 PM
Cutting butcher block for apron sink Plump Carpentry 4 07-17-2012 04:39 PM
Cutting a butcher block top franincanton Carpentry 7 01-09-2012 02:15 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
