I believe the north half of my house was framed with engineered truss system. Can they be cut to allow install of a skylight? How about multiple skylights? I found this space above the shower when I did my demo. I would like to put a skylight above the shower to reduce the volume of space to within code. The plan would be to do the same thing in the adjacent bathroom so the spaces are no longer connected. The bathroom fan will need to be moved but this is the least of my worries.
Is it a realistic plan to cut joists, after knowing EXACTLY how its is to be done, frame it, up to the roof, decking then have skylight installer finish install? Then do my own drywall and finish? Is this beyond a non carpenter DIY guy?
This space is much larger than 30 sq. ft. length is somewhere between 18-23 ft. by 6-8 ft. So 108-184 sq. ft. :furious: In order to remedy a problem was hoping could break up with skylights...:surrender: If the space between trusses is greater than 16 o.c. which it looks like, have to get ladder in and actually measure. Can I or someone frame onto side of truss to make the channel? Can get as narrow as 14" x 45 skylight???
The first picture sure looks like a fink truss with the lower end web behind the white plumbing vent under the blown-in insulation....... Turn your head clockwise 20*, you're looking up through the ceiling. The osb rakes down to the left outside wall.
If the trusses are 2' on center, (as they appear), install a skylight between two, as is the norm. It doesn't have to be centered in the room, just install the fan next to it.
"I would like to put a skylight above the shower to reduce the volume of space to within code." ---- Could you explain this more, please?
This is my framing plan since I need to provide support for drywall etc. I will need to do this 4 times along the space. Once over this bathroom and twice over center of adjacent bathroom and maybe the fourth over the new master shower, but very reluctant since this shower will get heavy use.
tomstruble can you go more in detail about condensation issues? On skylight or walls?
Hot steam/water vapor rises & will condense on the cooler surfaces
That will usually be the skylight
I take fairly long, hot showers at times & the water vapor condenses on every wall in my bathroom & the ceiling...no skylight
So even without a skylight you can have the condensation issue
A good fan will help get rid of the mositure
My bath fan is around 110 cfm, bathroom is round 330 cf
I have skylight in my 2nd floor bath
But we do not use the shower that much
I like the light in the bathroom
How about installing a velux suntunel? One, the deflector is far away from the bubble on the roof, so the deflector will stay at room temp., no condensation Two, you do not need to worry about the rafters. The tunnels are 14" wide at most. I can tell you from first hand experience that these give off so much light, that during the day, there is no point to turn on the lights in the bathroom.
Other option, leave the rafters, get a 48" skylight, decorate the rafters, and run sheetrock down and around them. I have done this too. 3 times in the last 2 years actually. Let me know if you want some pics.
You can see what I did. Sheetrock is not really attached to the trusses, its attached to the framing around them, but you can see them through that opening. I didn't cut any of them out. I polyurethane-d the hell out of the trusses, and they look like furniture.
Sorry for the crappy pic, but its the best I have on hand.
Are the skylights to reduce the attic space below 30sq.ft. to eliminate the required access? Would the solar tubes be too small to reduce the square footage enough?
Well after looking at things I have yet another hurdle. The soil stack is right there and if any of the skylights are to open I need 10' clearance? So if they are fixed and do not open is it still a done deal?
You CAN apply DW directly to trusses, but I prefer to strap the trusses first. You can also cut trusses but there is a special way to do it and you'd need an engineer to approve it.
As suggested, why not use a Sun Tunnel. You can get them with built in lights for night time use. A skylight in a bathroom is asking for condensation trouble.
I agree with the sun tunnels but they look more like recessed lights than a skylight. I plan to install two of them for my dark hallway. No reason to flip on a switch for 20ft.
I only installed the velux ones, but yea, they are great. You can buy the light kit for it, so that you can turn on the lights at night. You actually get the glow of the moon at night too. I love them, i have 3 down my hallway. Before it used to be dark, and you always needed to turn on the lights. Now I only turn on the lights at night only. Love it.
Does anyone make one that is designed for a north roof pitch? Anything is an improvement over the cave this bathroom is, but any with angled reflector to catch southern sun?
Get yourself the flex duct one, and you can turn the bezel inside to whichever exposure you want. You will understand once you get it. Or go to velux and find the installation instructions, they have pictures of what I'm talking about.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
