Ideas For Building A Sliding Safety Gate - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 02:49 PM   #1
Ideas for Building a Sliding Safety Gate
I need to find a child safety/security gate to stop our 15 month-old from entering our kitchen area, which has no door. Unfortunately we cannot use the traditional staircase style of gate that opens on a hinge, as it would hit a nearby pillar. What we ideally need is a gate that slides on some sort of track.
I haven't been able to find such a gate online or in stores, so I figured I might try to make one myself, using pocket-hole joinery. What I am not sure about is how to make the sliding mechanism - I was imagining some sort of sliding track like you have on bath-tub shower doors, where the top and bottom of the gate slides into a track with bearings when it is open. Any tips on where to find such parts or examples I can learn from?
Many thanks!
Ferrino is offline   Reply With Quote
Old 05-05-2013, 05:59 PM   #2
Rewards Points: 636
picture might help and a length
i am thanking of a sliding closet door track or pocket door track
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-05-2013, 07:35 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
what jaydevries said ^ length and photos
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-05-2013, 08:08 PM   #4
DIY staff
Rewards Points: 7,174
Size needed---C-channel on the floor along the wall---a roller or hook at the top--then a pocket on the other side of the door---flat panel or a flat gate come to mind---depending on the flooring,double faced sticky tape might be all that is needed for holding the c-channel to the floor.
Old 05-05-2013, 08:49 PM   #5
Rewards Points: 121
Not exactly, but might help -
I have saved this picture with the hopes of modifying the idea for our house:
http://www.houzz.com/photos/679460/O...itchen-houston
JamesRW is offline   Reply With Quote
Old 05-06-2013, 12:13 AM   #6
JamesRW: that's exactly the type of thing I had in mind - a gate with a couple of wheels on the bottom that roll along the floor. Except I would not be able to hide the gate when it's opened, unless I build some sort of enclosure.
Here are a couple of pics with dimensions. On the left-hand side (where the gate will retract and sit when the entryway is open) is the end of a wooden kitchen cabinet. The floor is wooden on the left, but the entry is ceramic floor tile. On the right-hand side where the gate will need to latch is drywall.
Thanks very much for any suggestions you have. Thinking about it, it would probably look a lot neater if I did build an enclosure for when the gate is opened, so as to hide the channel and the sliding mechanism. I guess I could simply extend the end of the kitchen cabinets and make a little box for it to recess into?
Old 05-06-2013, 01:51 AM   #7
Rewards Points: 2,210
Why not a regular gate swinging into the hall?
mae-ling is offline   Reply With Quote
Old 05-06-2013, 12:05 PM   #8
Because the gate would constantly need to be moved (it would block a walkway to the left when open and it would obviously block the kitchen when closed). I want it to be completely out of the way when open as it will only be used when cooking etc.
Old 05-06-2013, 12:10 PM   #9
GBrackins's Avatar
how 'bout an accordian style gate like in this photo ..... it's hinged on one side and pulls across to the other. I had one on my deck that only required a eye hook to connect it in the closed position
Gary
Old 05-06-2013, 12:14 PM   #10
Rewards Points: 2,516
What aisle are you attempting to block passage to?
hammerlane is offline   Reply With Quote
Old 05-06-2013, 12:44 PM   #11
The one marked in red - i.e. to the kitchen.
Thanks for the suggestion but my son would tear that down very easily. I need something more robust that will lock/latch against the other side.
Old 05-06-2013, 11:32 PM   #12
nothing sliding coming to my mind.
How about something hinged to the cabinet that could be up against the cabinet then swing right out?
Only sliding thing I can think of would be some sort of full extension drawer slides. Maybe something like this http://www.tchweb.com/tchstore/produ...wer-Slide.html mounted to the wall.
if you don't want the hardware visible when you slide it to close off the area (open the drawer so to speak) you would have to make it 6' so the 3' extra covers the slides mounted to the wall.
Old 05-06-2013, 11:36 PM   #13
Just wait if you made a cover for the sliding door, kinda a pocket then it could cover the slides and the door when slide on the wall then as the door was slide to cover the walkway the cover would cover the slidees, By job I think that might work.
Old 05-07-2013, 12:59 AM   #14
Bumpr1080's Avatar
Do you have a "the container store" near you? They're a chain in Denver that sells all manner of tracked items for under cabinets, closets etc ... For sure you can buy the hardware from them.
Also- if you're thinking about part of a shower door, why not buy an old shower door from a habitat for humanity ReStore or other kind of recycle home warehouse/ Craigslist?
Bumpr1080 is offline   Reply With Quote
Old 05-07-2013, 11:36 AM   #15
A hinge will not work because, due to the width of the required door to block the entrance, it would hit a pillar before it can sit move a full 180 degrees, to be against the cabinet.
I like that idea! And 36" slides would be a perfect size. Would you just put one slide along the top and one along the bottom, and then have a couple of wheels for it to roll along the floor and take the weight? Or would you not need wheels at all? I'm guessing the "door" will be pretty heavy.
What do you think the best type of "latch" is to place on the opposite wall and connect to the door? Needs to be childproof!
Thanks all!
Homeowners And Safety. Roofmaster417 Roofing/Siding 0 05-04-2011 12:41 AM
Gate Design Question rocknroll99 Building & Construction 5 04-13-2010 08:46 AM
Ideas for Temporary half wall type partition with gate. lenpharleyd Remodeling 4 12-27-2009 07:37 AM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
Gate for wooden privacy fence RookVega Landscaping & Lawn Care 2 11-09-2008 10:56 AM
