Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-21-2012, 12:12 PM   #1
Ideas for attaching markerboard to table
I'm making a small art table for my daughter. It is only 19" by 39" and I decided instead of using a wood product I would match this table with one her older sister has which is whiteboard marker board material that is 3/16" think, so it's light and strong enough. Now I'm trying to find the best way to attach this to the table top. I have the legs and frame already joined and was thinking either some kind of adhesive or corner molding. The other table has a routed edge on the inside, but then I have to cut this marker board with all the corners. I'm not comfortable enough yet to take that on. Any help I'd greatly appreciate it.
The frame is made up of Select Pine 1x3 and the legs are 2x2 Poplar. I used 2 pocket holes on each 1x3 to join each leg. Feels strong enough. I have pictures, but I don't see a way to post them here.
RodeoNCO is offline   Reply With Quote
Old 12-21-2012, 12:23 PM   #2
Sounds like construction adhesive is the way to go.
here's how to post images: http://www.diychatroom.com/faq.php?f...b3_attachments (though, I heard the site is having some trouble with images lately)
Seattle2k is offline   Reply With Quote
Old 12-21-2012, 01:02 PM   #3
I believe this will show it. Seattle2K are you talking about liquid nail or something like that?
Ideas for attaching markerboard to table-table_frame.jpg   Ideas for attaching markerboard to table-table_with_top.jpg
Old 12-22-2012, 10:47 AM   #4
AHH, SPANS!!!
might want to add some ribs to the structure to help the middle hold its weight. 3/16" is not thick and will sag at the middle point. maybe even drop in a thicker piece of ply flush to the top and then skin it with the white
hand drive is offline   Reply With Quote
Old 12-22-2012, 12:59 PM   #5
I have some ribs to go in there. Thanks.
Old 12-22-2012, 01:21 PM   #6
AHH, SPANS!!!
there is a tiny 1/2" by 1/2" outside corner that could trim out the top edges and keep stuff from sliding off the table as well. It would be neat if you could add a hinge and pivot so the table could be lifted on an angle from one side and propped up on the angle
Old 12-25-2012, 05:50 PM   #7
Yep, you got it.
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Building a coffee table, got a question aberrant Building & Construction 7 02-14-2011 01:02 AM
Table saw, spark and sawdust Shamus Safety 2 12-27-2010 12:09 AM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 04:18 PM
ideas on how to make a fold down work table kimber Carpentry 2 10-08-2009 12:56 PM
