I Want To Build A Decent Small Shed For Motorcycle Parking - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 12:40 PM   #1
I want to build a decent small shed for motorcycle parking
approx 8 x 10 or 10 x 12. Im thinking it will be on a concrete foundation with lag bolts holding the walls since concrete is what i do. I would also like some ideas on roof styles if anyone has input on this. Nothing too fancy, id like to do it fairly cheap. Garage style door in the front. Anyone have any ideas as far as plans for a complete DIY? I have a little framing exp building walls but thats about it.
Village Idiot is offline   Reply With Quote
Old 02-26-2011, 01:02 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
On thing to do if your local restrictions allow it would be to build 10' high sidewalls. - Same roof, a little more siding and 2' longer studs.
My son did this and it was amazing what it added for strorage and shelves on the walls and still keeping within the local code maximum footprint (his was 120 sf before it got complicated). His mower and sport vehicles took up a lot of floor space, but he could still load it up using shelves and hangers and keep the floor accessible.
concretemasonry is online now   Reply With Quote
Old 02-26-2011, 01:11 PM   #3
I didnt think of building it taller. Good idea though. Did your son aquire plans for this?
Old 02-26-2011, 01:47 PM   #4
He did not get plans, just drew up the footprint and he & friends built it up from the slab with too many anchor bolts.
He was worried about how the extra height would look, but since he tucked it in behind the garage and along the house (each 10-15' away) and had the same siding and roofing, it is not noticeable.
Old 02-26-2011, 01:58 PM   #5
Old School
Willie T's Avatar
If your bike is big (I have a 1,000 pound Goldwing) consider doors at both ends... basically a 'ride through'. It sure beats pushing the beast backward when you hit soft, spongy grass.
Willie T
Old 02-26-2011, 02:07 PM   #6
Old School
Willie T's Avatar
You also might want to consider pouring the slab on a fair slope so you can wash the bike in there and rinse the floor right out. Pour up-turned sills (about 6" high) all around the enclosed sides on the level so you can build wooden walls from there on up. The concrete sills will both keep the wood up out of the dirt outside, and keep inside water from rotting the wood out.
Willie T
Old 02-26-2011, 02:12 PM   #7
Old School
Willie T's Avatar
Of course this is always an answer if you can afford it.
http://www.cyclespinner.com/
or
http://motoparksystems.com/Home.html
Here's a cheaper one:
http://www.turnabike.com/
And one for less than $200:
http://www.pashnit.com/product/park-n-move.html
Willie T
Old 02-26-2011, 02:14 PM   #8
Around here, sheds are often built on a 4" slab on grade with 6" wide block (4" or 8" high) set around the perimeter and then the sticks on top to make flush-outs and cleaning easy and and keep the wood away from the soil moisture.
Old 02-26-2011, 02:22 PM   #9
Thanks I didnt think of that! Thats a good point and since its simple to pour the slab with a little stem wall I will definatelly do that.
HAHA about the 1000 lb goldwing in the grass, Im sure thats a pain to back out! Mine is only about 430 lbs. CBR 1000... Foot on the kickstand tilt and spin around (permitting the shed is wide enough to do this.) I will make sure of that. Double doors would be a great idea but i will want workbenches on back wall.
Old 02-26-2011, 02:25 PM   #10
or
Now that is COOL!!! Hmmmm got me thinkin now!
Can a DIY build a small in-ground swimming pool? zel General DIY Discussions 14 06-15-2013 09:42 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
small shed on larger concrete slab djtkach Building & Construction 10 07-23-2009 03:52 PM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 12:32 PM
How to roof a small shed???? Sellncars Roofing/Siding 2 09-22-2006 11:21 PM
