Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-26-2006, 04:20 PM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
I want to build 2 corner shelf units for speakers.
Hello there,
I have 2 speakers that are 8" deep and 8" wide, i would like to build a corner shelf for each speaker. The base is no problem, what is the safest way to hold the shelf plus the weight of the speaker in the corner? This is for a bedroom and i would like something a little more modern, not the cheap metal brackets. I ran a stud finder and it appears in each corner, the studs are about 2 inch's from the corner in either direction.
Thank you.
Sellncars
Sellncars is offline   Reply With Quote
Old 08-26-2006, 07:28 PM   #2
Master Craftsman
Big Dave's Avatar
I would build a shelf like in the picture below. You can put four screws into the back corner into the studs in the corner of the room.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 08-26-2006, 10:04 PM   #3
Sellncars's Avatar
That looks like a nice Decorative shelf plan. I didn't want anything ugly for a bedroom, but this idea i think would look good.
Thank you,
Sellncars
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be answering the question, what does a laser line level stud finder tool do? The tool that we're going to focus is primarily on in this segment of video clips is a combination stud... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will be detecting wood studs. When detecting wood studs, the first thing we need to do is set our stud finder to wood to tell it that we are in fact going to be detecting wood studs... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be talking about tips for buying a stud finder. I have two different types of stud finder tools and each one has its own pros and cons. On our first tool our stud finder gives us the... Read More »
Hi, this is ExpertVillage.com we're at Leigh Adams Discount Sales and my name is Daniel Daly. Today we're going to be demonstrating how to set up your perfect home theater, be it a little screen, LCD, Big LP's, even giant screens on the wall. You have... Read More »
The next item that we are going to be using to make our straight lines on our 2 x 4's and 2 x 6's and other materials that we use to cut, it would be located as a square. The square is used for many different items, uses. It has your degrees and your... Read More »
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 12:41 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
