Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-31-2007, 03:52 AM   #1
Default I need to build a stand to hang a chair
Hi guys.
I want to build a free standing mount to hang a sky chair from...
http://www.skychairs.com/chair.htm
I want to be able to put the chair out in the yard but I don't have any trees to mount it from. I was thinking about making something from 4x4's? It needs to support at least 250#'s.
Any ideas are appreciated. Thanks!
xray328 is offline   Reply With Quote
Old 03-31-2007, 09:55 AM   #2
You could build two ends like an "A" and then attach one across the top connecting the two. Hang the swing from that. Just make sure if it will be outside to use pressure treated or something that is rot resistant to moisture such as redwood or cedar.
cibula11 is offline   Reply With Quote
Old 03-31-2007, 11:31 AM   #3
Use sky hooks!
Zero Punch is offline   Reply With Quote
More On This Topic
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Common in-house pollutants and allergens are second-hand smoke, pesticides, gas and fireplace emission, pollen, mold, pet dander and mite fragments. Many of these pollutants are in common household items such as the carpet. Energy-efficient devices... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Today, we're changing an air conditioning compressor on a '96 Ford Explorer. In this step, I'm going to demonstrate the proper service procedure for piercing the refrigerant can, firing the engine, and beginning the charging process. Now, what you're... Read More »
Not only is mold unsightly, it can cause health problems. Mold grows in humid or damp areas of your house and will continue to grow unless removed. After removing the mold, you can prevent it from growing back with a few simple steps. Here are a few tips... Read More »
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 08:29 AM
Chaise Lounge chair plans MillerClemsonHD Carpentry 4 06-25-2007 12:32 PM
Newbie considering a build peloncito Building & Construction 1 06-18-2007 12:13 PM
Painting Chair for Nursery cibula11 Painting 11 06-08-2007 10:39 PM
To Build or Not To Build scoby1978 General Discussion 6 05-27-2007 06:39 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
