Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-08-2011, 07:44 PM   #1
I keep ripping sanding belts
Hi
I bought a used Bosch Belt Sander 3x21". I never used one of these before. I am sanding down a hundred year old floor joists that I salvaged from the dumpster. I'd like to make a table from them. I started off with a 36 grit paper and after doing one face of the wood I ripped it. I put another one in and it ripped after finishing another face and a half.... I am now on my third one and it ripped a bit already..... What am I doing wrong?
greendot is offline   Reply With Quote
Old 10-08-2011, 07:58 PM   #2
Civil Engineer
If the sander is improperly adjusted, the belt can track to the side, contact the metal housing, and rip. You need to read the instructions in the manual for adjusting the tracking, and make sure the belt tracks down the middle.
Old 10-08-2011, 08:13 PM   #3
KemoSabe
loneframer's Avatar
Some of the cheaper belts are lapped at the joint and will rip if the lap snags on a splinter if the belt is installed improperly. The lapped belts are directional, indicated by an arrow on the inside of the belt.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 10-08-2011, 08:14 PM   #4
KemoSabe
loneframer's Avatar
Actually, with 100 year old wood, you may be wearing the belt out by the time you complete 1 face.
Old 10-08-2011, 08:33 PM   #5
I'll look into the manual.
I sure hope this isn't going to require so many belts.....
The wood looks incredible though.... I will post pictures soon.
Old 10-08-2011, 08:39 PM   #6
Super Moderator
Salvaged wood can yield some wonderful colors--I find Minwax wipe on Polly is a great finish for old wood.
Look for a knob on the side of the sander---that should be the tracking knob---it moves the front wheel and allows you to keep the belt centered.
Nails in the wood can rip a belt in an instant.
Old 10-08-2011, 10:05 PM   #7
Sanding belts are directional. Make sure you put them on in the correct orientation.
Ron
B. Franklin 1759
Old 10-09-2011, 08:54 PM   #8
In a little over my head
Belt rubbing on the side, really tough old wood, belt on backwards, imbedded nail?
Find someone with a planer (or rent a benchtop unit). Buy them new set of blades and run the boards thru couple of passes. It'll make e'm smooth and flat. Gluing them together will be much easier. Or, buy an old fashioned plane, and learn how they did it in the old days. It's fun and surprisingly fast(er than you think).
ratherbefishing is offline   Reply With Quote
ice wires vs ice belts? jeffw_00 Roofing 7 08-12-2011 12:39 PM
staining a deck and sanding erinherbst Painting 1 07-02-2011 10:48 PM
Car Painting and sanding h3llfir3 Painting 19 08-11-2009 10:44 PM
Car Painting and sanding h3llfir3 Automotive Repairs 1 08-10-2009 11:02 PM
Sanding marks.......will they show yummy mummy Building & Construction 9 07-24-2008 12:43 AM
