I Joist Hanger Fasteners - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 10:53 AM   #1
I Joist hanger fasteners
I have to replace a damaged 6" joist header and maybe the joist hangers
Because of a confined crawl space for swinging a hammer in that area, I was going to use screws instead of nails to fasten the new joist hangers
What type or grade of screws would you recommend ?
Is it OK to enlarge the hanger holes to accept a larger screw ?
stymie222 is offline   Reply With Quote
Old 05-14-2011, 11:32 AM   #2
Rewards Points: 1,002
Rent or buy a palm nailer.
There are no non-engineered alternatives to properly sized nails in your application. Enlarging the holes is not allowed
Anti-wingnut is offline   Reply With Quote
Old 05-14-2011, 02:18 PM   #3
I understand integrity but these are only 6" floor joists to re-attach, in a home built in 1952. Room size is 10' X 12'.
I would follow procedure if I was installing a new floor system with 9 1/2 " or larger joists and hangers
Old 05-14-2011, 02:56 PM   #4
Why bother asking the question then? All you want is justification
Old 05-14-2011, 05:29 PM   #5
Civil Engineer
Rewards Points: 4,566
Simpson sells a line of structural screws which are specifically allowed as an alternative to nails on some of their brackets. Download the Simpson catalog, and see if there is a joist hanger that will allow structural screws as an alternative to the standard 10d nails. Else get a palm nailer as previously described.
Old 05-14-2011, 11:25 PM   #6
Rewards Points: 212
exterior 2 inch screws are fine. Screw in fact are stringer than nails.
bluebird5 is offline   Reply With Quote
Old 05-15-2011, 12:19 AM   #7
Rewards Points: 212
He's asking the question because he's hoping that someone will give him a solution to his situation, kinda like one poster who mentioned the Simpson screws that are intended for hangars, instead of (erroneously) telling hem that nails are the only solution.
A Squared is offline   Reply With Quote
Old 05-15-2011, 12:25 AM   #8
Like this hogwash?
Old 05-15-2011, 09:16 AM   #9
Rewards Points: 212
Like this hogwash?
Yeah, that answer isn't accurate either. That's the trouble with forums like this. You ask a question, and for every correct answer you get, you get several like yours and mr "any screw is good" which are incorrect. You gotta separate the wheat from the chaff.
Old 05-15-2011, 09:34 AM   #10
I am aware of the Simpson products, before I even did my intial respomse, I searched looked for an application. This was difficult given that the OP wanted to attach either a 6" TJI to a header, or 2 X 6 sawn lumber to a TJI. That is why I told him to use nails.
Old 05-15-2011, 01:26 PM   #11
Rewards Points: 212
Old 05-18-2011, 09:26 AM   #12
Registered User
Termite's Avatar
Absolutely incorrect. Screws are nowhere near as strong as nails in shear, which is what they're resisting in a hanger. There is no application for deck/exterior screws (or similar) in the installation of joist hangers, period. The only screws that are acceptable for use are the SD/SDS-types that Daniel mentioned, and even they are normally only specified for use in heavier beam hangers.
The advice to use nails is good solid advice.
Old 05-18-2011, 02:58 PM   #13
Tizzer's Avatar
Rewards Points: 452
I'm thinking the OP went ahead and used screws anyway.
Tizzer is offline   Reply With Quote
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 11:26 AM
Placing joist hanger on top of ledger instead of hangers. hnd83 Landscaping & Lawn Care 1 04-15-2011 09:32 AM
Joist doesn't match dimension of joist hanger! Stan Shmenge Building & Construction 9 03-15-2011 08:35 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
