Hurricane Tie - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-05-2014, 12:36 AM   #1
thebarn61's Avatar
Rewards Points: 35
hurricane tie
Hello again,
Any suggestions on which tie(s) or configuration of strap(s) I should use for this application? I have not found a specific Simpson or for this, any advice would be greatly appreciated. Thanks again
thebarn61 is offline   Reply With Quote
Old 04-05-2014, 08:30 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 996
there are framing anchors that can be bent to suit different angles L-70 's are for 2x8, L90 for 2x10
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
thebarn61 (04-05-2014)
Old 04-05-2014, 08:36 AM   #3
thebarn61's Avatar
Rewards Points: 35
thanks, I figured I would have to use those but wasn't sure if there was a specific tie pre fabbed for this. Not much room because of the angle for those though?
thxs again
Old 04-05-2014, 11:19 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
those are a PITA! you might need to nail the bracket in place first and then set the double down into it otherwise you cannot nail it. you will have a hard time nailing the double once you do set it down in there. good luck!
hand drive is offline   Reply With Quote
Old 04-05-2014, 04:57 PM   #5
Rewards Points: 90
Two ledger locks each through the outside framing? Ron
ront02769 is offline   Reply With Quote
shingle roof leak and hurricane questions paulmars Roofing/Siding 52 10-17-2013 11:08 PM
Work rules for Hurricane gregzoll Off Topic 4 09-03-2011 12:40 PM
Will wire mesh make my room hurricane safe? toddbeck Building & Construction 18 02-11-2011 01:04 PM
Hurricane clips... is this ok? TravisT Building & Construction 5 12-24-2007 05:41 PM
