Humidex - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 02:44 PM   #1
humidex
hey just bought a humidex. the cut needed in the joist is 6 1/4''. no where around here has that hole saw available, what can i use to make it larger, i used a 6' hole saw already, pls help, a snow storm is coming...lol
lil_lelo is offline   Reply With Quote
Old 01-20-2010, 04:45 PM   #2
Registered User
Termite's Avatar
Not sure what a Humidex is, but I can assure you that there is rarely a circumstance that you can cut a 6"+ hole in a joist! 1/3 the total depth of the joist is the max, with no less than 2" of wood remaining top and bottom.
Old 01-20-2010, 04:55 PM   #3
you can cut some pretty big holes in TJI joists depending on how far from bearing you are
Tags
hole saw , humidex , joist
