How Was Wooden Fence Built - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-18-2013, 11:45 PM   #1
Lord of Slums
Rewards Points: 1,974
How was wooden fence built
My neighbor had a privacy fence built that I like a lot. I have been trying very hard to figure how they built it. The top seems pretty straight but the bottom appears to follow the uneven ground. The spacing is all done very nicely. Anyone care to comment on the basics of building a wooden fence on uneven ground?
mj12 is offline   Reply With Quote
Old 07-19-2013, 06:31 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Tight string up top to set the height. A wood jig to place between boards to set spacing.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
jaydevries (07-20-2013)
Old 07-19-2013, 06:53 AM   #3
Rewards Points: 13,228
Posting a picture of there fence would be a big help so we can see what your talking about.
Old 07-19-2013, 02:34 PM   #4
Davejss's Avatar
Rewards Points: 740
Fences on uneven ground should be plumb but not necessarily level. Nothing looks worse to my eye than when someone tries to make their fence level when the ground is not. I just drove by a recently completed stockade fence. One end of the twenty foot run is on the ground.nthe other end a cow could walk under.
Davejss is offline   Reply With Quote
Old 07-19-2013, 02:51 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Saddle for every a$$.......
On uneven ground, just my personal taste, I like a stepped fence. (Can be more expensive to build as having different size picketts involved)
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 07-19-2013, 04:02 PM   #6
Old School
Willie T's Avatar
If you work at it, your fence can look as good as mine. Yeah, there were some issues, but I handled them...
Willie T
Old 07-20-2013, 03:30 PM   #7
Old School
Willie T's Avatar
Are you guys hesitating because you're not really sure............ ?
Over on CT, my rear end would STILL be on fire for that post.
Willie T
Old 07-20-2013, 03:56 PM   #8
kwikfishron's Avatar
Rewards Points: 170
I thought... that doesn't look like Florida.
kwikfishron is online now   Reply With Quote
Old 07-20-2013, 04:38 PM   #9
We like you... and were trying to be polite.
(Actually, I think we were afraid you were not kidding, and we have been listening to ya and taking your advice for too long)
Best
Peter
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Willie T (07-20-2013)
Old 07-20-2013, 04:39 PM   #10
I thought... that doesn't look like a fence.
Old 07-20-2013, 04:49 PM   #11
Rewards Points: 170
Well, I knew it wasn't Willie's fence so I didn't bite.
Old 07-20-2013, 05:22 PM   #12
Old School
Willie T's Avatar
To be truthful, there are a couple of fences in my neighborhood that don't look much better than that one.
Willie T
Old 07-20-2013, 06:11 PM   #13
AHH, SPANS!!!
Rewards Points: 1,166
fence posts should be plumb and fencing boards fit plumb onto fence railing and the bottom of fencing cuts to contour of land with tops being the most even (level)overall with posts set at height to work with grade of land as well.
if fencing fits between posts then even spacing outward from the center of the space is used just like a deck pickett spacing.
hand drive is offline   Reply With Quote
Old 07-20-2013, 06:49 PM   #14
Best
Ya know.... Isn't it an issue of design, personal taste, consistant with the area issue (white picket/verse ranch rail/verse chain link/ and I guess even verse barbed wire).
Is it an actual privacy objective, tall and unbroken pickets, or just definitional/decorative, lower and open with filials decorative elements.
Maybe, driving the neighborhood, deciding on what you like... and then the best advice I can give you, put in what your wife says.
Best
Peter
How to add a dividing fence to chain link fence and house with siding catburke Building & Construction 1 10-10-2013 01:33 AM
"Better" or "proper" way to build this 4' wooden picket fence? Dave88LX Building & Construction 4 06-08-2012 04:52 PM
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 06:43 AM
Wood fence is warping skittles1984 Carpentry 2 02-21-2011 12:27 AM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 07:03 PM
