-   -   How was wooden fence built (http://www.diychatroom.com/f14/how-wooden-fence-built-183830/)
mj12 07-18-2013 10:45 PM
My neighbor had a privacy fence built that I like a lot. I have been trying very hard to figure how they built it. The top seems pretty straight but the bottom appears to follow the uneven ground. The spacing is all done very nicely. Anyone care to comment on the basics of building a wooden fence on uneven ground?
PoleCat 07-19-2013 05:31 AM
Tight string up top to set the height. A wood jig to place between boards to set spacing.
joecaption 07-19-2013 05:53 AM
Posting a picture of there fence would be a big help so we can see what your talking about.
Davejss 07-19-2013 01:34 PM
Fences on uneven ground should be plumb but not necessarily level. Nothing looks worse to my eye than when someone tries to make their fence level when the ground is not. I just drove by a recently completed stockade fence. One end of the twenty foot run is on the ground.nthe other end a cow could walk under.
MTN REMODEL LLC 07-19-2013 01:51 PM
Saddle for every a$$.......
On uneven ground, just my personal taste, I like a stepped fence. (Can be more expensive to build as having different size picketts involved)
Best
Willie T 07-19-2013 03:02 PM
1 Attachment(s)
If you work at it, your fence can look as good as mine. Yeah, there were some issues, but I handled them... :wink:
Willie T 07-20-2013 02:30 PM
Are you guys hesitating because you're not really sure............ ? ;)
Over on CT, my rear end would STILL be on fire for that post.
kwikfishron 07-20-2013 02:56 PM
199 Attachment(s)
I thought... that doesn't look like Florida.
MTN REMODEL LLC 07-20-2013 03:38 PM
We like you... and were trying to be polite. :yes:
(Actually, I think we were afraid you were not kidding, and we have been listening to ya and taking your advice for too long):thumbup:
Best
Peter
MTN REMODEL LLC 07-20-2013 03:39 PM
I thought... that doesn't look like a fence.
kwikfishron 07-20-2013 03:49 PM
199 Attachment(s)
Well, I knew it wasn't Willie's fence so I didn't bite.
Willie T 07-20-2013 04:22 PM
To be truthful, there are a couple of fences in my neighborhood that don't look much better than that one.
hand drive 07-20-2013 05:11 PM
fence posts should be plumb and fencing boards fit plumb onto fence railing and the bottom of fencing cuts to contour of land with tops being the most even (level)overall with posts set at height to work with grade of land as well.
if fencing fits between posts then even spacing outward from the center of the space is used just like a deck pickett spacing.
MTN REMODEL LLC 07-20-2013 05:49 PM
Best
Ya know.... Isn't it an issue of design, personal taste, consistant with the area issue (white picket/verse ranch rail/verse chain link/ and I guess even verse barbed wire).
Is it an actual privacy objective, tall and unbroken pickets, or just definitional/decorative, lower and open with filials decorative elements.
Maybe, driving the neighborhood, deciding on what you like... and then the best advice I can give you, put in what your wife says.
Best
Peter
