How To Unscrew Or Tighten Old Screws In The Deck? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-02-2009, 10:24 AM   #1
how to unscrew or tighten old screws in the deck?
I just finish power washing my deck. I noticed that many screws are sticking out so I tried to screw them down with a screw gun. Some of them broke, and on some head got stripped. However, not single screw i was able to tight or unscrew without breaking or stripping. Could anyone tell me what can I do? Thanks
renoet is offline   Reply With Quote
Old 03-02-2009, 10:47 AM   #2
Rewards Points: 109
You could try using a screw extractor, such as GrabIt. It sounds like they used drywall screws which simply were not meant for exterior use and have rusted over the years.
BimmerRacer is offline   Reply With Quote
Old 03-02-2009, 02:11 PM   #3
Any old deck screws will become very hard to unscrew or screw in tighter. In most cases the head strips out or it snaps off. Best bet is if you can - unscrew them & use new screws
I have a 12x12 deck out back that I installed last year
Once the boards dry out & shrink I'm going to take it apart & move the boards closer together.
Old 03-02-2009, 02:26 PM   #4
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,186
Drill them out
Drill the heads off the bad screws and sink new screws. You are wasting your time fighting the old ones, not worth the effort. Use Torx screws, stainless if you can afford it. Dorf Dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 03-02-2009, 02:37 PM   #5
Carpenter
DecksEtc's Avatar
Why on earth would you want to do that?
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 03-02-2009, 04:44 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
ive never had much luck with those screw extrators that you chuck in your drill
Tom Struble is offline   Reply With Quote
Old 03-02-2009, 05:04 PM   #7
Rewards Points: 178
I'm having the same problem with some of the screws on my deck. But I only notice it when the snow shovel stops suddenly and I'm still moving forward . Is there a way to put the screws into the wood so they don't work their way out?
Could the rest of the screw work it's way up to the surface? Ouch!
gma2rjc is offline   Reply With Quote
Old 03-02-2009, 09:15 PM   #8
Sometimes giving the head a good tap with a hammer before trying to back them out will help dislodge them. Doesn't work all the time but it helps considerably.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-02-2009, 10:14 PM   #9
I've used the grabit extractor bits and they work like a charm every time on getting stripped out screws out.
mrpurty is offline   Reply With Quote
Old 03-04-2009, 01:12 PM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
An impact driver will go a long way to removing old deck screws without stripping the heads. Certainly beats a drill/driver every time.
Old 03-04-2009, 03:42 PM   #11
Dorf dude...
Impact Driver
I totally agree with the impact driver. You could use the diamond paste Screw Doctor together and you should get good results. Impact drivers rule! Dorf Dude...
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
failing miserably at screwing in 2 inch deck screws gordie howe Carpentry 17 10-28-2008 12:00 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 04:09 PM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 08:51 PM
