How To Trim Window - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 07:43 PM   #1
Question
How to trim window
I'm stuck on how to properly trim this window. This is new construction and there is only a stool and apron. The inside (casing?) is drywall and not a trim piece. I want to trim out the window, but am stuck with what to do about the inside ---Do I let it as is and add the trim to the outside or do I add wood to the sides and top, then add trim to the outside.
I apologize in advance if this is a stupid question...it's my first house & I want to get some expert advice before I do something incorrect.
Thanks!
ryan16 is offline   Reply With Quote
Old 02-24-2009, 08:21 PM   #2
Old School
Willie T's Avatar
It's probably done equally both ways, wood returns or just drywall. Neither is wrong. Just look around at some others, and decide for yourself.
Your stool (sill to us Southerners ) is painted now, so I assume you are going to paint all of this trim white? Doing so, the drywall won't be a huge distraction.
If you do choose to return wood to the windows, keep it pretty thin so you won't ruin the look of your window frames by covering almost all of them with wood. It looks tacky to have a return almost all the way to the glass frame edges.
If you do go wood for the returns, the inside wood usually goes on first, and the wall face trim covers that front edge... with or without a stepped reveal. But not always. (Aesthetically, your choice)
Willie T
Old 02-24-2009, 09:21 PM   #3
Rewards Points: 1,016
I think it's fine the way it is -
Rhe windows in my house are the same, but even without the stool and apron - all depends on the look and feel you are going for.
Old 02-25-2009, 04:09 PM   #4
Rewards Points: 179
hang curtains or shades on the outside measure (instead of inside) and then you don't even need trim.
windowguy is offline   Reply With Quote
Old 02-25-2009, 06:49 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
If you are wanting the custom look of having your window trimmed out with casing you can do it with or without having a wood return to the window, but the problem I see from your picture is that the stool extensions ( the portion of the stool that extends beyond the window opening) are too short for you to set your casing on ( meaning that even 2 1/4" casing would be wider than the stool extension) and will require new stools, and possible new aprons (the vertical part under the stool) for it to look proper.
HTH,
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 02-26-2009, 04:27 PM   #6
All the "returns" on my house are drywall.
I actually prefer the look to "stained" wood returns - they feel too "heavy" to me.
So I just paint all my returns to match the wall color.
Subsequently I looked at your picture and said "whats wrong with it the way it is now???"
Garasaki is offline   Reply With Quote
Old 02-26-2009, 04:50 PM   #7
Thanks to all for the suggestions. The stool only extends 2 3/4" from the drywall return, so I probably would have to add a wood return in order for the casing to look right. Might try a thin return & narrow casing and see how it looks. If not, I might leave it as is.
Old 02-27-2009, 08:56 AM   #8
Once you get a window treatment on it won't look so naked
Old 02-27-2009, 06:24 PM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
If your stool extends 2 3/4" you could use 2 1/4" colonial casing either mitered or with rosettes unless you are wanting something more substantial looking. It really comes down to what YOU want (or what the better half wants in most cases!)
Man of many hats
Old 02-27-2009, 09:56 PM   #10
Old School
Willie T's Avatar
You seem to be wanting to remain in the ballpark of some degree of conventionality, so here is pretty much the standard layout:
The stool should protrude from the wall surface by appx 1-1/4".
The casing should set back from the edge of the window return by 3/16", all around.
The stool should extend past the outside edges of the casing by 1" on each end (side).
The full length of the apron should line up with the outside edges of the casing.
Willie T
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
Replacing Inside Window Trim lensgaga Remodeling 3 09-20-2008 06:46 PM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 08:49 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
