How To Trim The Sides Of Hollow Core Doors - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 02:21 PM   #1
how to trim the sides of hollow core doors
I just bought all new 6 panel hollow core doors and some are to wide and I need to trim or sand to fit whats the best way to do this?
eyestellsall is offline   Reply With Quote
Old 03-30-2011, 03:41 PM   #2
Old School
Willie T's Avatar
Straight edge and a circular saw.
Willie T
Old 03-30-2011, 03:45 PM   #3
Rewards Points: 24
I run a piece of masking tape the length of the door first to minimize chipping, and I think it was TCleve (?) who suggested in an earlier post to scribe your line with a utility knife before cutting it, for the same reason.
Old 03-30-2011, 04:33 PM   #4
Jay123's Avatar
If they're already pre-bored for door knobs, I'd make sure to trim the hinge side (you'll have to re-mortise for the hinges if you take much of the door off).
Jay123 is offline   Reply With Quote
Old 03-30-2011, 05:38 PM   #5
Rewards Points: 282
and if you trim too much off you may have the internal frame fall out (if you cut the glue line out.....no way to tell until you cut)...if so you can just rip a 2x4 down (i believe to about 1 3/8ths, if i remember right the hollow doors are about 1.5" and the skins are about 1/8 each side...i remember a 2x4 is slightly too thick at 1.5")...
anyway...not a necessarily fun project on a hollow door.
probably easier to take the door jamb/frame apart on one side and move it if there is room (and you can either re-cut the top jamb or if only a small distance you can possibly fill/caulk).
why the non standard openings? Old house?
jcrack_corn is offline   Reply With Quote
Old 03-30-2011, 06:16 PM   #6
KemoSabe
loneframer's Avatar
Power planer will do the trick.
http://www.amazon.com/Bosch-1594K-6-.../dp/B000067S14
loneframer is offline   Reply With Quote
Old 03-30-2011, 09:44 PM   #7
Old School
Willie T's Avatar
I use this kind of a straight edge. But I made mine with 5/8" mdf. It works well to virtually eliminate any surface chipping from the teeth of the saw blade.
http://www.youtube.com/v/CH5dW-QcgeI...</param><param
Willie T
Old 03-31-2011, 12:30 AM   #8
If it does not work some brands allow custom order widths.
beerdog is offline   Reply With Quote
Old 04-01-2011, 05:53 AM   #9
Before you trim the doors you must first measure the size of the doors and where you can put it, to avoid over trimming.
desiree_furman is offline   Reply With Quote
hollow or solid core door for pocket door RobertN Building & Construction 4 10-12-2015 08:55 PM
bowed NEW hollow core doors? cbzdel General DIY Discussions 2 12-04-2010 06:25 PM
1/2" diameter hole in hollow core door noahweb Carpentry 4 02-16-2010 09:36 PM
PreHung Doors and Trim JETJR Carpentry 4 01-15-2010 08:44 PM
What primer should i use on my trim, doors and window sills? MGB_ Painting 5 01-13-2010 06:49 PM
