How Is This Trim Made - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 11:48 AM   #1
Rewards Points: 150
How is this trim made
Trying to figure out how the edging on the trim of the locker is made. Is it done with a router? If so, any guesses on what kind of bit?
Thanks!
How is this trim made-image-1823055408.jpg   How is this trim made-image-2040222952.jpg
stradt03 is offline   Reply With Quote
Old 04-14-2013, 12:28 PM   #2
ocd carpenter's Avatar
Yes that's done with a router, using a roman ogee bit.
ocd carpenter is offline   Reply With Quote
The Following 3 Users Say Thank You to ocd carpenter For This Useful Post:
oh'mike (04-17-2013), stradt03 (04-14-2013), woodworkbykirk (04-14-2013)
Old 04-14-2013, 12:33 PM   #3
Rewards Points: 150
Thanks!
Old 04-14-2013, 04:30 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
that's most likely an mdf face frame to get those cleans routed edges...
hand drive is offline   Reply With Quote
Old 04-14-2013, 09:20 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
yup.. mdf frame with a router edge.. you can tell by how the inside corners have a rounded profile instead of a tight 90 degree angle for the profile making the turn
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (04-14-2013)
Old 04-16-2013, 05:07 PM   #6
Household Handyman
Rewards Points: 1,408
The inside rounded profile can be cut in wood while it is on the cabinet. You would have to make a template for the foot of the router to follow, not the bit. I have seen this done once the face framing of the bookcase or cabinet is completed. Using a template will guide the router so that the bit makes the exact radius and profile you want on the finished edges. This take time, thinking, and patience but looks so good.
Old 04-16-2013, 11:59 PM   #7
Yep, its a router bit. Pretty standard bit with a bottom baring. Should be easy to find at your local store.
jessrj is offline   Reply With Quote
Old 04-21-2013, 05:13 PM   #8
Rewards Points: 196
Picture on the left. Isnt that just a simple round over bit which has an undersized bearing and the cutter is lowered so the end of the round over part is say a 1/16" below the router base?
Jason34 is offline   Reply With Quote
Old 04-22-2013, 11:13 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
If I were going to make that profile, I'd use a simple quarter-round bit, set the depth to produce a 1/16" reveal, and then use a roller guide on the router baseplate set to produce the same 1/16" reveal on the other corner of the bit. It's definately not an ogee profile. I could do that same thing with a lumber faceframe, so it doesn't need to be mdf.
Old 04-22-2013, 09:24 PM   #10
chitownken's Avatar
Rewards Points: 510
Thought that was a roman ogee at first, but blew up the picture and it does look like was done with a round-over bit. Went out to the garage and looked at the bits. Have a round-over bit with a 1/2" shaft that could have a smaller bearing put on it that would do this cut without having to build the guide for the base. Would make it much easier to have the bearing on the bit. Good catch, Jason.
chitownken is offline   Reply With Quote
Old 04-23-2013, 07:23 AM   #11
kwikfishron's Avatar
Rewards Points: 178
Looks like a "beading" bit to me
kwikfishron is online now   Reply With Quote
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 07:00 PM
Painting ceiling, walls, and trim MsKitty32 Painting 33 03-16-2013 10:18 AM
How to attach trim near the ceiling? TrailerParadise Building & Construction 6 03-11-2013 05:18 PM
Need help caulking and filling nail holes in my trim hadees Painting 13 11-25-2012 11:32 PM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
