Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-27-2012, 12:13 PM   #1
How to Transition From Stair Skirt Board to Base Board?
What is going to work to make a good transition from my skirt board to the floor's base board?
The stairs will be carpeted.
I plan to add base cap on top of the 3/4" plywood skirt board.
http://www.lowes.com/pd_140858-746-E...URL=&facetInfo=
How to Transition From Stair Skirt Board to Base Board?-lower-stair-case-left-side.jpg   How to Transition From Stair Skirt Board to Base Board?-lower-stair-case-right-side.jpg
dieselscout80 is offline   Reply With Quote
Old 06-27-2012, 01:13 PM   #2
What does your baseboard look like?
Thanks for the pics, that is great!
mae-ling is offline   Reply With Quote
Old 06-27-2012, 01:18 PM   #3
Did you build those stairs?? Look new and for surely breaking several codes..
CopperClad is offline   Reply With Quote
Old 06-27-2012, 02:12 PM   #4
What codes do you feel are violated?
Refinishing the stairs.
Old 06-27-2012, 02:37 PM   #5
1. maximum riser height should be no more then 8'', appears you are more.
2. 5/8'' drywall needs to be attached to the bottom of the stairs for fireproofing.
3. Minimum 4 inches from the bottom of the stringer to where the intersection of your tread/riser intersect.(looks very close on this one)
4. Every riser must be consistent within 3/8 of an inch.(looks very close on the bottom step)
Old 06-27-2012, 05:16 PM   #6
Mod
kwikfishron's Avatar
That would be 5" min.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 06-27-2012, 09:28 PM   #7
8"
hadn't thought of sheetrock there
5" stringers are 2x12
yes
Do you have any advice on question which is what I'm concerned about?
Old 06-27-2012, 09:38 PM   #8
I had pretty much this same problem, I couldnt think of anything so just put baseboard and ended at the wall. does not look good. maybe u could skip the cap and paint the skirt white along with the staircase walls and caulk the 2 for a smooth transition
Toilet Bowl is offline   Reply With Quote
Old 06-27-2012, 11:08 PM   #9
Stair builder
For the base where the wall continues you just have the bisect the angle. For the one which has to turn the corner without being able to transition to level first you need a different profile base, here is a link- http://www.thisiscarpentry.com/2010/...board-returns/.
It does appear that you have some code issues however there is no code requirement for sheetrock under stairs in the IRC.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
BigJim (06-28-2012)
Old 06-27-2012, 11:27 PM   #10
http://inspectapedia.com/interiors/Stair_Fire_Stop.htm
Old 06-28-2012, 12:03 AM   #11
Stair builder
While I feel that drywall is a good idea, I don't see where any code is referenced. At the Stair Manufactures Association conference a couple of months ago I asked David Cooper who helps write the codes for the IRC if there is any requirement and was told at that time that no such code exists. Fire blocking in walls is a code requirement.
Old 06-28-2012, 12:10 AM   #12
Maybe its not a code every where then.. http://codes.lp.findlaw.com/nycode/MDW/5/1/152
Old 06-28-2012, 12:59 AM   #13
Keith gives a good link, requires custom height base and trim on base as well as skirt.
Old 06-28-2012, 10:22 AM   #14
The code you are showing is for Multiple Dwelling not a single family home and it looks to be a New York code and I certainly don't live there.
Old 06-28-2012, 10:24 AM   #15
Newbie Bill
Great link Keith.
This is the way I would do it.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
some questions on stair case skirt boarding (how to measure, cut, materials) dwichman Carpentry 2 04-06-2009 06:40 PM
Small Gaps between tread & skirt board jcpullen Carpentry 14 08-26-2008 02:06 PM
Maximum base board loop length Mike Warner HVAC 1 05-01-2008 12:48 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
