How To Transfer A Design Onto Wood? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 06:04 PM   #1
r0ckstarr's Avatar
Rewards Points: 2,052
How to transfer a design onto wood?
I built a 2ft wide by 3ft long by 14inch high wooden box based off of the design of an old crate I seen.
I used cheap white-wood to build it, and I stained it with Minwax Ipswich Pine stain.
I then took a design from a wine crate, ran it through photoshop, and modified the design. It's a black design with no colors to it.
How can I transfer the design onto the wood? I could hand draw the entire design, but I am looking for a less time consuming approach.
I found this video and was considering this method. But, then I started wondering if maybe I shouldn't have stained the wood first. And, if I didn't stain it first, would the stain make the design bleed?
Any other suggestions or ideas?
r0ckstarr is offline   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
oh'mike (01-23-2014)
Old 01-22-2014, 08:48 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
I don't know how it would work over stain but on bare wood you can print it out and iron it on, works pretty good on tee shirts.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
r0ckstarr (01-23-2014)
Old 01-23-2014, 06:27 AM   #3
Rewards Points: 1,298
Carbon paper is one method I used many times to transfer patterns. Another old trick from when we used to do custom paint work on cars was to use a sewing pounce wheel. Small wheel with teeth that make a line of penetrations in the paper pattern. You then place the paper over the work surface and use a chalk bag to leave a chalk trace thru the holes on the surface. Once the paper is removed you can trace with pencil or outline with tape.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 01-23-2014, 01:14 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
id do the carbon paper thing, it works very well. a buddy does custom artwork on skateboard decks, he first draws it out on regualr paper then transfers it with carbon paper
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 01-23-2014, 01:33 PM   #5
DIY staff
Rewards Points: 7,174
Great video---I want to try that heat transfer----that technique has a lot of uses.
Old 01-23-2014, 02:10 PM   #6
r0ckstarr's Avatar
Thanks. I'll try both techniques on some scrap wood and see how they turn out.
Old 01-23-2014, 02:51 PM   #7
Rewards Points: 147
The laser toner inks aren't going to be light fast. You could print it the size you want position it, hinge the bottom with tape, drop it down to expose the back, spray with art adhesive, flip it back up, burnish it down and use an Exacto knife to cut out the design. Then spray or roll the paint, stain, whatever.
Rango is offline   Reply With Quote
The Following User Says Thank You to Rango For This Useful Post:
r0ckstarr (01-24-2014)
Old 01-23-2014, 04:16 PM   #8
DIY staff
I still want to try it even if the sun will cause some fading over time---
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
