How To Stain A Staircase Railing - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-14-2014, 08:58 PM   #1
How to stain a staircase railing
Hello all,
We are having our oak hardwoods stained a darker brown, however the staircase railing is still natural color and has a semi gloss applied to it. Any suggestions on how to match the staircase railing, that doesn't involve hours of hand sanding?
thanks in advance.
thundercracker is offline   Reply With Quote
Old 01-14-2014, 09:11 PM   #2
Rewards Points: 14,000
No easy magic way to do it.
All the old sealer has to go. Need bare wood so the stain can soak in.
Old 01-19-2014, 04:27 PM   #3
Originally Posted by thundercracker View Post
Hello all,
thanks in advance.
I have done refinishing on furniture and any type of wood pieces you can imagine. There is a "magic bullet"... The first step is to remove the existing varnish/clear coat. you can employ a chemical... However, for stair railings, i would much rather use a sponge sander and take my time. Yes, this gets to be labor intensive and it is for this reason refinishers charge so much!
As to the staining, if you are going from a lighter color to a darket color, you do no need to sand the lighter color to bare wood. However, you have to give a very good scuff. I would start with an 80 grit sand paper and finish with a 180. Since youre scuffing, no need to obtain a bare wood status.
www.superiorhomesolutions.net
www.superhomeinspections.net
jackmd1 is offline   Reply With Quote
Old 01-19-2014, 05:55 PM   #4
Davejss's Avatar
Rewards Points: 776
You can scuff the surface with a Scotch Bright pad and then wipe it down with a tack cloth. Then I would check out a product called Polyshades. It's a stain/poly all in one.
I have had success using it over previously polyurethaned wood.
Davejss is offline   Reply With Quote
Stain washes right off railing undersc0re Painting 21 02-15-2013 11:42 PM
staircase railing needed? carpenal Carpentry 5 06-28-2011 09:39 AM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 06:32 PM
Need Help. Having trouble sanding darker stain from staircase Timotay Flooring 7 10-26-2009 12:53 PM
Paint choices for wooden staircase railing shuss Painting 3 09-01-2007 08:42 PM
