How To Stain New Oak Treads? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-19-2014, 02:43 PM   #1
Rewards Points: 1,050
How to stain new oak treads?
Hi
A contractor will install new oak treads ("retrotreads") on my stairs, with withe risers
I will do the finish (staining the treads and painting in withe the risers and stringers)
What is the best method to stain the oak treads: should i use a brush, or a piece of cloth?
I will apply 1 or 2 layer of stain (depend on the color) and will apply polyurethane on top of it (4 or 5 layers I guess)
french_guy is offline   Reply With Quote
Old 01-19-2014, 03:14 PM   #2
Rewards Points: 13,988
I use Gel stain, brush it on let it sit for about 15min.then wipe it off with a clean rag.
Have plenty on hand, your trying to wipe off the excess not just move it around.
Dave Sal (01-19-2014)
Old 01-19-2014, 03:37 PM   #3
Dave Sal's Avatar
Rewards Points: 718
I'm sure you're aware that if they are installed unfinished, then you will not have use of your stairs for a few days while you finish them yourself. Any chance you can prefinish them before they are installed? If not, then perhaps you can do every other stair so you can still use them while the stain and poly dry.
Dave Sal is offline   Reply With Quote
Old 01-19-2014, 04:23 PM   #4
Yes, that's the plan: every other stair
Will be relatively easy to explain the the wife and daughter, but i'm not sure about the dog (unless the dog understands just fine, but not the wife..)
The Following User Says Thank You to french_guy For This Useful Post:
Old 01-20-2014, 02:18 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
joe. are you using gelstain as in its stain and poly in one? we used it on one job last year with a refinished hardwood floor and it was a total nightmare.. the homeowner wanted the floor darker after the first coat was on and we couldnt really do anything about it.. the hardwood guy tried mixing more stain in with it and it looked horrible.. reason being the wood wont absorb the stain after its already been coated, the varathane seals the pores of the wood
woodworkbykirk is offline   Reply With Quote
Old 01-25-2014, 02:56 PM   #6
Stairguy
Millertyme's Avatar
Rewards Points: 508
Keep in mind that a gel stain or even your typical minwax stain will not darken with additional coats. The wood will only absorb so much color and thats it. Unless you brush it on and don't wipe it off, it won't darken more than the first coat. Dye stains will darken with subsequent coats. One stain is dry apply 3 coats of poly, i like oil based poly, and sand with 220g in between coats.
Millertyme is offline   Reply With Quote
Should I replace wall skirt when installing new retro treads on existing stairs hkeiner Carpentry 12 02-15-2013 07:21 PM
replaced stair treads dhungy Flooring 5 06-20-2012 10:21 AM
Removing stain from deck machouinard Painting 20 09-08-2011 09:12 PM
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 01:57 PM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 01:04 PM
