How Snug Should A Custom Window Fit - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-02-2009, 10:50 PM   #1
how snug should a custom window fit
I just had custom windows replaced in my home. During the installation I noticed that there was a gap inbetween the top of the window and the top of the opening. How much room should there be?
I was told that the windows are measured to the 1/8th of an inch and that would make me believe that there shouuld fit real snub not so that the gap is obvious visable.
the installers told me that was standard and they insulate the space and cap it off and caulk it shut.
I am presuming that will work but it dosen't seem right to me that there was a obvious gap. Am I correct in my assumption.? and how much gap should there really be on custom fit windows.
Thanks for your help.
Surjit
surjit is offline   Reply With Quote
Old 07-02-2009, 11:04 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thats' the way it's done my friend. There is no way windows could be ordered to fit any differently on replacement windows. If the adjacent areas are painted don't let them use 100% silicone to caulk the cracks. They should use a paintable caulk and 100% silicone IS NOT PAINTABLE.
Old 07-03-2009, 06:15 AM   #3
Replacement windows can be be sized to fit very closely on the sides, 1/8-1/4" is normal. But the window has to be tilted in, so the top needs some extra clearance room. Vinyl windows come with a head expander that fills that gap. The air gaps should be filled with non-expanding foam or insualtion. I use DAP foam, never really hardens, moves with the window.
Old 07-03-2009, 08:53 AM   #4
Yup, 1/8 - 1/4 gap is normal
Too tight & you can run into problems with wood swelling w/humidty.
Then the windows either don't open or they stick
Tags
custom fit window , replacement windows
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Custom Curved Window - Replacement AndrewF Building & Construction 3 01-12-2009 10:32 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
