How To Smoothly Cut Cabinets - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 05:10 PM   #1
How to smoothly cut cabinets
I've gotten myself into a "difficult" project with my cabinets. I am currently cutting some of the cabinet doors (don't ask) and need to get a smooth edge.
The doors are particle board with a veneer. They are tall.
My table saw gives a cleanish cut, but it's kind of unwieldy and I can't really get the cut straight.
I just tried my jig saw with a "clean wood" bosch blade and was disappointed to find out that the cut wasn't clean at all.
The problem is that I need a cut that is both precise and smooth. Anyone got any ideas? Did I just buy the wrong jig saw blade?
diyorelse is offline   Reply With Quote
Old 10-10-2010, 06:05 PM   #2
DIY staff
Rewards Points: 7,174
Your table saw must be a little crumby one--a full size table saw should give you a clean straight cut--
Do you have a router? A router with a straight cutting bit and a guide clamped to the door will give you a clean finished cut---Rough cut the door about 1/6 inch long and make the final finish cut with the router.
A jig saw will not give you a good finish cut-----Mike----
Old 10-10-2010, 07:36 PM   #3
firehawkmph's Avatar
Rewards Points: 1,920
Diy,
If you know anyone local that has a festool plunge saw with the guide track, it will give you a clean cut. They are a pretty amazing tool. I bought a few months ago for cutting furniture grade plywood. It does a wonderful job with no chipping on either the top or bottom edge.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-10-2010, 07:43 PM   #4
a nice table saw with a finish blade and tape (on the laminate sides) will take care of any chipping.
wnabcptrNH is offline   Reply With Quote
Old 10-10-2010, 09:57 PM   #5
jschaben
Rewards Points: 502
Hi Mike, circular saw with a good straight edge guide and finish blade, tape on the laminate side should give a fairly decent cut. Router with a top and bottom bearing flush trim bit would do a nice job but depending on how much you need to take off it could take several passes.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
oh'mike (10-11-2010)
Old 10-11-2010, 08:18 AM   #6
Jig saw????
This sounds very familiar, cutting doors for a taller or wider fridge by chance? that is my current dilemma . I have talked over several options and as confident as I am I won't tackle shrinking a cabinet door when there are knowledgeable guys out there who can do it for me.
I have also found several local shops and the Habitat for Humanity Re Store have a lot of excess door panels from prior projects and used cabinet pieces. That said there are some great folks on line here. Do what I do . Post some photos or more and see what comes up here for ideas to make your life easy before you get in deep
Chemist1961 is offline   Reply With Quote
Old 10-11-2010, 08:33 AM   #7
Rewards Points: 5,336
The work needs to be stable from one end of the door to the other. Set up an outfeed table for the door to rest on while you push it through the cut. If it's a small table saw with a small fence, cap the fence to make it longer.
It might be easier to clamp a straight edge to the doors and cut it with a circular saw with the correct blade.
Put the jigsaw away, it's not the correct tool.
Ron
Old 10-11-2010, 08:58 AM   #8
Civil Engineer
Rewards Points: 4,938
For all my doors, especially ones with laminate (I assume you mean Formica or similar), I use a router with a straight carbide bit. You need to set up the fence correctly for the operation. I always make multiple passes, typically the first one is 1/4 inch, the next few can be 1/2 inch deep, the last one is about 1/4 inch. Gives a razor sharp cut as long as the bit is sharp, no chipping. I have never used a pilot bit for this type of operation, just a fence.
Daniel Holzman is online now   Reply With Quote
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Kitchen cabinets - Are Ikea cabinets good? What other mfgs have you used? whataboutj Kitchen & Bath Remodeling 24 11-09-2012 06:14 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
How are the premade HD and Lowes Cabinets? twilightcall Carpentry 10 05-25-2008 10:23 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
