How Should I Match This Trim From The Stairs To The Baseboard? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2014, 08:00 AM   #1
Rewards Points: 406
How should I match this trim from the stairs to the baseboard?
After doing the flooring and installing new (bigger) trim I have to figure out how to transition from the stairs to the baseboard. Any tips?
How should I match this trim from the stairs to the baseboard?-2014-06-19-07.47.27.jpg   How should I match this trim from the stairs to the baseboard?-2014-06-19-07.47.18.jpg
RyanD is offline   Reply With Quote
Old 06-21-2014, 08:43 AM   #2
Rewards Points: 13,732
Reverse the angle of that trim in the bottom picture on the right that's against the case moulding at the top to where it meets the top of the skirt moulding.
Why the change in height of the base?
Unless you have higher then 8' ceilings I'd keep the shorter base.
Old 06-21-2014, 10:10 AM   #3
Rob
Robpo's Avatar
Rewards Points: 826
I would cut the stair trim vertical. Cut a soldier out of 1x2, 1/2" higher than tall base. Nail it to stair trim so it sticks out from wall 1 1/2". Bring tall trim around corner and die into soldier.
Robpo is offline   Reply With Quote
Old 06-23-2014, 03:11 PM   #4
Rewards Points: 5,974
Run the short one around the corner and let it die against the door casing. Just that short a run won't be very noticeable to anyone but you.
The Following User Says Thank You to ToolSeeker For This Useful Post:
PaliBob (06-23-2014)
I want a light-to-medium stained baseboard / window casings / and door trim. PLEASE NO WHITE FOR ME! Help! tresangeles Painting 1 04-01-2012 10:42 PM
Measuring trim for mitered baseboard installation abbyqueue Carpentry 3 07-28-2009 12:54 PM
Removing paint from baseboard and trim tripower Painting 12 02-24-2009 12:02 PM
Differing size of Baseboard Trim offered at the Hardware store pk1023 Carpentry 7 02-23-2009 05:04 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 12:31 PM
