How Should I Build This Countertop? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 11:03 PM   #16
Anyway you do the splice is fine as long as you run build up across the joint underneath. Make sure to belt sand the seam after the glue dries. Also lay the laminate sheet out flat over night before you laminate.
jessrj is offline   Reply With Quote
The Following User Says Thank You to jessrj For This Useful Post:
r0ckstarr (05-11-2013)
Old 04-16-2013, 11:08 PM   #17
r0ckstarr's Avatar
Rewards Points: 2,012
That was what I was thinking. Thanks for the reassurance and confirmation. As for the laminate laying out, I've had it laying out perfectly flat for the last 2-3 weeks in a spare bedroom.
Any suggestions on the best way to put the two together, besides the build up strips? Screws / nails? I don't want to run a nail through the sides unless I have too, in fear of splitting the ply's.
r0ckstarr is online now   Reply With Quote
Old 04-17-2013, 08:40 AM   #18
The best would be glue and biscuits with a clamp but an easier way would be to screw some bracing strips on the bottom of the joint on one side. Put some wood glue on the seam. Then put some pressure on the joint as you screw the braces to the other side. Just make sure its the bottom side so you don't have any damage on the side the laminate is glued to.
r0ckstarr (04-17-2013)
Old 05-24-2013, 07:57 AM   #19
r0ckstarr's Avatar
Just updating this thread in case someone pulls it up in a search in the future, and wonders what the outcome was.
Here's the finished result.
Laminate countertops
What is best way to build a detached 24x24' Garage with a Basement underneath? eastpamt1 General DIY Discussions 10 12-07-2011 12:10 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Marble countertop excess length doesn't leave enough space for stove! sbrink Kitchen & Bath Remodeling 1 12-28-2010 04:21 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
