How A Saw Stand's Dust Box Work - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 11:32 AM   #1
Rewards Points: 866
Making a dust box for a saw stand
I am getting set to build a cabinet type stand for my miter saw. The plans are here. http://www.popularwoodworking.com/up.../290/fea39.pdf
I am going to modify them some to allow for use of an outside shop vac instead of the built in one. I know I can plug a hose into the dust port of my saw, but I wonder how the dust shelf of this cabinet works. Shouldn't there be an opening or several in the top of the cabinet to allow sawdust to fall down onto the shelf. (And if I go with the adjustable platform per the plan, shouldn't it have similar openings?) Then my shop vac would also plug into an opening in the back of the dust box. (Actually, I would plug its hose into a pvc pipe that teed into the back of the dust box and the saws dust port. I would add a little inner door so as to turn the dust shelf into a dust box.
Does this make sense?
Klawman is offline   Reply With Quote
Old 12-06-2009, 02:39 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I have one of the ChopShop hoods from Fastcap. They can be folded down when not in use.
The new ones are all white and mount directly to my DeWalt 12" SCMS
(pic is from FastCap)
http://www.amazon.com/Fastcap-FastCa.../dp/B000VS4K7K
Disclaimer
& Stay Safe
.....Bob Lavery
Old 12-06-2009, 08:20 PM   #3
Landscaper
PaliBob
how do you like your chop shop hood??
DBRhino is offline   Reply With Quote
Old 12-07-2009, 03:19 AM   #4
Tool Geek
PaliBob's Avatar
DBR, I keep the ChopShop hood set up all the time in my garage for non production use. As you can guess the garage no longer holds a car. The hood helps keep the dust down. It is not easily portable so I use a $100 10" Hitachi. Overall I give the ChopShop a solid B.
Disclaimer
& Stay Safe
.....Bob Lavery
Tags
dust box , miter saw , saw stand
Sheetrock dust under carpeting in basement... Please help. ben319 Building & Construction 7 09-15-2009 03:35 PM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 10:16 AM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Control Dust in Basement Remodel Siamese Remodeling 4 03-19-2008 02:47 PM
