-   -   How to run new cable to outside? (http://www.diychatroom.com/f14/how-run-new-cable-outside-79594/)
hoggin03 08-24-2010 10:13 PM
I want to install a new coax line from the outside to the inside of my house. I am doing it behind my TV which is in a niche that is located directly over my gas fireplace. The niche and fireplace are in a bump out on the back side of the house. It is drywall, 2x4 studs, and vinyl siding. I assume there is a vapor barrier, fiberglass batt insulation, and housewrap.
My question is, what is the best way to go about doing this? I have made sure there is no electrical, gas, or plumbing lines. Should I just drill a hole to the outside? I was thinking I would remove siding and get the coax out and run it behind the siding. I figured I would cut a hole in the drywall and put in a box for the coax outlet. My main concern is the actual drilling of the hole - any concerns I should have? Also, how should I go about sealing things back up?
Thanks in advance for any input.
I put this in electrical but it isn't getting any answers...I guess it is more suited for carpenters anyway.
2 threads on same issue merged
Moderator
gregzoll 08-25-2010 08:25 AM
If you have a basement or crawl space, I would go that way. Punching a hole through the wall always smells of a hack job, and shows sloppiness.
liquidvw 08-25-2010 10:29 AM
If you want to go through the wall to the outside, then buy an installers bit. Bits come in 1/2 and 3/8. You drill from the inside to the outside. One the bit is through, dont remove it. There is a hole in the end of the bit. Strip back the coax and attach it to the bit, then pull the bit and the coax through the wall. :thumbsup:
