How To Replacing Termite Damaged Ceiling Joists - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 08:03 PM   #1
how to replace termite damaged ceiling joists
How do I replace ceiling joists,what tools will I need?
expediter is offline   Reply With Quote
Old 08-20-2009, 08:33 PM   #2
Registered User
Termite's Avatar
Your question is much too general. We need to know the available access, ceiling type, span, spacing...Is there an attic at all, etc.
A paragraph of details and even a photo or two of the room/framing would work wonders...
Old 08-20-2009, 09:01 PM   #3
ok i understand. joists are in the basement of an old Philadelphia Pa. row home and tommorow i will get more details of joists
Old 08-20-2009, 09:39 PM   #4
Registered User
Termite's Avatar
Also clarify if they're ceiling joists or floor joists (for the 1st floor), since you're talking about a basement.
Old 08-20-2009, 10:58 PM   #5
joists
will do,that makes sense
What do I do with 2x4 ceiling joists? benjamincall Building & Construction 28 12-29-2011 09:04 AM
Aligning walls to ceiling joists? dstylez Building & Construction 4 03-12-2009 05:45 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Replacing damaged sub floor evolve Flooring 8 11-10-2007 02:06 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
