How To Repair These Stairs? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 01:59 AM   #1
how to repair these stairs?
We pulled up the carpet on the stairs of our 1950's house. Some of the treads have split and look rough. My goal is to get these sturdy and looking good enough for now and then when we redo the flooring, down the road, use some sort of false tread product that matches the new floor. I can't access underneath the stairs without cutting through the drywall (which is a possibility). When i look closely at where the treads meet the stringer, it looks like the treads aren't set in grooves on the stringers - does this mean I could just pry up the treads? then access underneath the treads from the top to reinforce and repair the treads as well?
how to repair these stairs?-img_1724.jpg   how to repair these stairs?-img_1725.jpg   how to repair these stairs?-img_1726.jpg   how to repair these stairs?-img_1728.jpg
thekingofboggle is offline   Reply With Quote
Old 04-22-2012, 05:35 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
If the treads aren't mortised into the skirt boards, then yes you can pry them up and repair/replace.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-22-2012, 08:04 PM   #3
Rewards Points: 150
It's possible that the stairs were site built with a carriage and a stringer, if that is the case the tread can be pried up from the carriage without disturbing the stringer to any large degree, but the riser is likely nailed to the rear of the tread. Try prying the tread up and know that when you are done you are likely going to pull down the gypsum board beneath to attach the riser to the new tread and possibly shim the tread to eliminate creaks. good luck.
TheCamper is offline   Reply With Quote
Old 04-22-2012, 10:29 PM   #4
Rewards Points: 14,312
It looks like someone tryed to use soild wood treads instead of laminated.
Soild tends to crack and of cup.
Why not just remove those and install new treads. Not much more expencive then over threads and should hold up better.
Old 04-23-2012, 08:22 PM   #5
CrossWorks's Avatar
Rewards Points: 150
I agree. Stay ahead of the game and just get your stairs replaced and ready to meet the new flooring some day. Then again maybe that's not in the budget. I'm sure that you're aware by replacing any of the steps, to be prepared to stare at one or two odd colored steps for a while.
Just like paint....carpet covers everything!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-28-2012, 08:11 PM   #6
Rewards Points: 272
it looks like the treads are mortised into the risers. I would try and get a look at them from underneath. That would tell you the whole story of how they were made and answer all of your questions.
fixrite is offline   Reply With Quote
Old 04-28-2012, 08:16 PM   #7
Agreed. Or cut out the one that's split already.
Evstarr is offline   Reply With Quote
Old 05-04-2012, 06:20 PM   #8
I'm with fixrite. I think the treads have a tenon on the ends that go into the carriage. Rip it out and start again
mrgins is offline   Reply With Quote
Old 05-04-2012, 08:21 PM   #9
Stairguy
Millertyme's Avatar
Rewards Points: 508
they are not housed stringers, if they were you wouldnt see a gap like that. Mortised and tenon is highly unlikely on a stair, especially looking at the quality of the treads. Id rip them up and put new ones.
Millertyme is offline   Reply With Quote
The Following User Says Thank You to Millertyme For This Useful Post:
BigJim (05-04-2012)
Old 05-04-2012, 09:28 PM   #10
Only one way to find out. Mortised stairs are unusual but it has nothing to do with the gap that you see. If it is mortised, it could pull away, leave a gap like that and still have the tenon supporting it.
Old 05-04-2012, 10:47 PM   #11
Rewards Points: 272
Not meaning to sound like a broken record, but you WILL need to access the backside of the stairs to determine if they are mortised. To me they look like they are mortised and tenoned and wedged. My other house has just that kind. With all that said you will still need to determine its method of being built. Hope you have a good day.
Old 05-05-2012, 07:55 AM   #12
Stairguy
Millertyme's Avatar
Rewards Points: 508
This is the reason stairs are not usually put together using typical mortise and tenon joinery. Instead the stringers are routed and he tread is long and wedged from the bottom. This is more typical and is by far the best method. There is a difference.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 06:13 PM
Painted the stairs ... . kimber Painting 8 10-07-2009 11:50 AM
Basement Stairs Repair tmbrink Building & Construction 5 03-18-2009 06:08 AM
