How To Repair Deterioration On Inside Of Window Frame? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-13-2007, 02:33 PM   #1
Rewards Points: 660
How to repair deterioration on inside of window frame?
I would like to repair the damage visible in the picture, the damage extends along the entire bottom of the window. I would like to just tear into it but I'm not sure what is beneath the surface. I think there is aluminum or something like that under the paint. Is anyone familiar with this type of window installation and knows how to go about fixing it?
How to repair deterioration on inside of window frame?-upload_bad_window1.jpg
darsunt is offline   Reply With Quote
Old 08-13-2007, 04:33 PM   #2
zel
Rewards Points: 150
Send a message via AIM to zel
It looks like the area is getting damp and that is the main reason it looks that way. You will probably have to figure out where/why water is getting to that point. Yu might need a new window, or just some caulking or flashing on the outside to start, but more then likely, there is more damage that isnt visible until you tear it apart.
zel is offline   Reply With Quote
Old 08-13-2007, 04:40 PM   #3
Rewards Points: 5,326
This is a two step process. You need to find out where the water is getting in and repairing the damage that's been done.
It looks like a flanged aluminum window. There are nailing flanges on the exterior, that are buried under the exterior finish. There should be drainage holes or channels under the screen so water can run out. Many times these are caulked and/or painted over so the water get into the framing underneath. Look at the other windows that don't exhibit this damage to see how they are set up.
Ron
The metal underneath is the steel corner bead used to finish an outside corner.
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
How do I repair my window frame sherlock Carpentry 18 12-20-2006 09:54 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
