Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-16-2009, 11:53 AM   #1
How to repair Bedroom Door Strike Plate
Could anyone help, on an Idea of how to repair the wood where a doors strike plate was once at , the area has all rotted out an needs replaced, But I'm quite sure how much it would take, or any how to videos out there
jjchips is offline   Reply With Quote
Old 11-16-2009, 12:58 PM   #2
Remodeling Contractor
If you have a router this is the way to go. You cut out the bad part with the router. then glue a patch tightly into the cut out. Trim the corners with a sharp chisel.. Sharp is the operative word here. No router? do it all with a sharp chisel. Did I mention Sharp!? Leave the thickness of the patch stock slightly more than the cut. Then sand flush, prime and paint. You will never see the patch.
Old 11-16-2009, 02:42 PM   #3
bob's solution is the best but if you don't have the ability to do it that way you can remove the damaged material fill back with Rockhard putty sand and paint. This is like a plastic filler and will also require sharp tools to reinstall your strike. did i mention sharp?
Old 11-16-2009, 02:44 PM   #4
I guess this depends on the depth of the bad wood. Anything more than a 1/4" or so, the putty or any filler will eventually shrink and fall out.
Old 11-16-2009, 03:03 PM   #5
thank you both for your replies I like the idea of the router / wood chisel, I spoke with a man at Lowes and he tried to sale me a whole door , frame and all, but I'm trying to find the least cost repair possible,
Old 11-16-2009, 05:53 PM   #6
Super Moderator
Bob suggested the best method I know of. Nice details too. Thumbs up Bob!
Old 11-16-2009, 07:49 PM   #7
nice thing about the Rockhard putty is how stable it is and not prone to shrinkage.
Old 11-16-2009, 09:23 PM   #8
Household Handyman
This is not intended to be an ad, it's from my experience with this very problem. I used to try to hold up a small router to do this, not good for me. I've tried drilling holes and finishing up with wood chisels, this works, and as mentioned--SHARP is the key here. I now have a multi-tool, with an oscillating blade that is the trick for this. Drilling holes helps also, and then cut out the bad wood with the saw, and finish with a good SHARP chisel. I agree with cutting the replacement piece slightly larger and using a good wood glue. After the glue dries, then sand to a smooth finish, then start as if new wood altogether.
how to fix rotted sill plate carole2cd Building & Construction 7 03-26-2011 07:19 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
What do you guys think of this roof repair job? darsunt Roofing 7 08-21-2009 09:43 PM
sill plate repair over block foundation MARLE Building & Construction 14 05-04-2009 09:03 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
