How To Remove Old Rusty Raised Deck Nails - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 06:10 PM   #1
win
How to remove old rusty raised deck nails
We are trying to restore our deck that has been much neglected. Many of the deck nails have rusty and raised heads.
I feel they should be removed and replaced with screws that will not rust.
But how do we remove the old. Saw this tool Cooper Group 56 Nail Puller
and didn't know if this would work without damaging the wood surrounding the nails.
Any suggestions would be appreciated.
win is offline   Reply With Quote
Old 05-17-2009, 07:40 PM   #2
Five Star's Avatar
If the nails are proud of the wood surface, take a cats paw or flat bar and a take a cedar shim. slip the shim in under the bar and pull the nail out. keeping the shim under the bar will prevent un sightly marks!
GOOD LUCK!
Five Star is offline   Reply With Quote
Old 05-18-2009, 05:56 AM   #3
win
Thanks. The luck is probably what we need.
Old 05-18-2009, 09:37 AM   #4
Old School
Willie T's Avatar
You've chosen one of the best nail pullers in the Cooper. With the sliding striker, you can bite into nails that don't even have a head, and pull them right out easily. At $50 bucks, it may seem expensive, but when your job is done, you'll be thankful you paid a little more for a designated tool like this.
Willie T
Old 05-18-2009, 10:30 AM   #5
win
Thanks Willie T. I'll probably buy the tool to make the job easier. Even with using the claw on the raised heads I'm anticipating pulling a lot of the heads right off.
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 07:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
New Deep Tub ~ Needed Raised Deck .. Faucet for Deep Deck? Hisgirl Plumbing 1 01-17-2009 11:00 AM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 09:25 AM
Deck nails jimgibson Carpentry 12 10-09-2005 02:22 PM
